| Home > General Chat > Oil filter removal tool | |||||||
928 Posts Member #: 65 Post Whore South Yorkshire |
30th Mar, 2009 at 10:20:25am
My strap one is worn out and before I splash out on a new one I wondered if oil filter pliers were any good, or what else people used or found effective.
![]() 2102 Posts Member #: 432 Post Whore Swindon |
30th Mar, 2009 at 10:25:39am
On 30th Mar, 2009 Neil8p said:
My strap on is worn out hehehe i use the pliers type one, the only problem i have found is you can crush the bottom of the filter if its a little tight. apart from that a top tool :) edit: this is mine:
Edited by Mini_Andy on 30th Mar, 2009. |
30th Mar, 2009 at 11:32:06am
My strap one is worn out and before I splash out on a new one I wondered if ........................
30th Mar, 2009 at 11:39:33am
I have a box set of cups. The sit on the bottom of the filter and then plug onto your rachet. makes getting them of under the front of the car nice and easy On 11th Feb, 2015 robert said:
30th Mar, 2009 at 12:14:59pm
I've a chain one from machine mart, just the same as a strap really except it will never break or wear out.
30th Mar, 2009 at 12:33:47pm
The past few times ive removed an oil filter was with a sheet of wet and dry. Gives you enough grip to undo by hand :) |
30th Mar, 2009 at 12:59:05pm
Screw Driver through the middle of it! 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
30th Mar, 2009 at 01:00:16pm
Pair of latex gloves on and a bit of muscle also seems to work. If something is worth doing, it's worth doing half of. |
30th Mar, 2009 at 01:49:12pm
I made my own chain type with an old timing chain welded to a scrap socket extension, its worked fine for over 25 years. |
998 Posts Member #: 2178 Post Whore Leyland, Lancs |
30th Mar, 2009 at 03:00:52pm
I use the pliers type - same as the ones pictured above - never had an issue with them. On 15th Jul, 2009 fastcarl said:
a breif struggle ensued but Will emerged the victor with a pair of undies in his possesion On 21st Sep, 2009 apbellamy said:
No, but you did chuck your guts up over my front gate the Saturday before! You even managed to get a bit in your arm pit... |
549 Posts Member #: 5327 Post Whore Dudley, West mids |
30th Mar, 2009 at 03:01:23pm
Them plier ones are the daddy. I've used a load of different ones on other cars and found them to be the best out all of em. :) |
![]() 159 Posts Member #: 1997 Advanced Member Lichfield |
30th Mar, 2009 at 06:04:54pm
i use the blue point one similar to this
30th Mar, 2009 at 06:45:31pm
hahahahahahahhahaha what an error that was with your strap on comment!!!
30th Mar, 2009 at 07:01:23pm
On 30th Mar, 2009 Nic said:
On agricultural filters they tend to have a nut on the bottom so you can just use a spanner to get it off WHY CANT THEY DO THIS WITH CAR FILTERS??????? ££££££££££££££££££££ If something is worth doing, it's worth doing half of. |
30th Mar, 2009 at 07:16:20pm
Monkeh's ones the best, bought one a few years ago and they rule! (expecialy for a mini, can you even use the pliers with a non flip fronted mini?)
30th Mar, 2009 at 07:35:11pm
On 30th Mar, 2009 slater said:
Monkeh's ones the best, bought one a few years ago and they rule! (expecialy for a mini, can you even use the pliers with a non flip fronted mini?) I just take the grille off for a bit of extra working space. On 15th Jul, 2009 fastcarl said:
30th Mar, 2009 at 07:55:15pm
hahahahahahahhahaha what an error that was with your strap on comment!!! On agricultural filters they tend to have a nut on the bottom so you can just use a spanner to get it off WHY CANT THEY DO THIS WITH CAR FILTERS??????? On 11th Feb, 2015 robert said:
30th Mar, 2009 at 07:59:18pm
That was a cartridge filter housing. If something is worth doing, it's worth doing half of. |
30th Mar, 2009 at 08:03:44pm
On 30th Mar, 2009 minimadmotorman said:
That was a cartridge filter housing. On 11th Feb, 2015 robert said:
30th Mar, 2009 at 08:08:09pm
Nic is talking about a nut being welded to the end of a normal oil filter. If something is worth doing, it's worth doing half of. |
![]() 3756 Posts Member #: 1709 I like granny porn. LONDONSHIRE |
31st Mar, 2009 at 05:31:58pm
ive used an old belt in the past On 2nd Oct, 2009 Vegard said:
I bet my first wank came quicker than your first mini turbo These new modern turbos with their quick spool up time, would make the competition harder. On 15th Aug, 2011 robert said:
phew!!! thank you brett for smashing in my back doors .( not something i imagined writing... EVER) |
315 Posts Member #: 3013 Senior Member Epsom Surrey |
31st Mar, 2009 at 06:44:18pm
snap on one in the picture is a great tool and doesnt damage the filter!! |
493 Posts Member #: 3894 Senior Member sallys gap. garden of Ireland |
1st Apr, 2009 at 12:52:24am
On 30th Mar, 2009 MikeRace said:
Driver through the middle of it! Screw Driver through the middle of it! |
1st Apr, 2009 at 02:06:04am
thats the way to do it imo :)
Screw Driver through the middle of it! Drives
