Home > General Chat > Crimping/swaging ends on hydruallic hoses
I want to be able to make my own hoses like so:
Is this the sort of item needed?
http://www.lister.co.uk/ecommerce/response...rimping%20press
or is there a cheaper alternatve?
Joe
998turbomini25
Member #: 2276
sheffield / derby
I've used these to make my own lines up in the past, there an compression type fitting so you only need a spanner!!
http://www.merlinmotorsport.co.uk/p2936/BA...oduct_info.html
hope it helps
luke
Mr Joshua
Member #: 1954
Luton Bedfordshire
998 I would not advise useing that type for high pressure hydraulic fittings. The pipe used is not suited for that kind of application.
Own the day
really,
i thought 600 series -3 hose was ok to about 3000 psi.
Are you saying that Goodridge are telling us porkies, when they say that their 600 series hosing is suitable for brake and clutch aplications?
http://www.goodridge.co.uk/buy-goodridge-hoses.htm
Edited by Sprocket on 7th Apr, 2009.
i want to swage the ends on like in the above pic
just not sure what equipment is commercially available to do so?
Mr Joshua
Member #: 1954
Luton Bedfordshire
Not at all, it depends on the application intended.
Own the day
Clutch and brakes?
Mr Joshua
Member #: 1954
Luton Bedfordshire
600 hose is all good. As I never knew what the application was for I counceled caution as operating temp range came into mind I have suffered the uncomfortable situation of being blasted in the face with full system Hydraulic pressure after an inappropriate pipe failed due to temp fatigue.
Own the day
looks like one of these badboys are the way forward:
http://www.endeavourinternational.ltd.uk/e...CFQsMGgodBD9mUQ
quite a few guides on youtube too, but all seem to be 1"+ diameter like the sort you would find on plant equipment.
Ive fired them an email to see if they do one for our application.
Joe
Why are you so set on swaging lines? If self assembly fittings are good enough for WRC cars, they are good enough for me.
couple of reasons
id like to pedal a few kits locally, and maybe branch out into doing custom lines for kit cars etc,
no one here on the island can really provide this service locally, and there is a huge market for it
the generic kits out there imo is massively over priced. i paid £80 for about 20" of goodridge braided hoses for my volvo, if i do 10 cars on my own during my lifetime, ive near enough broken even.
im not saying the diy compression fitting jobs arent good, they are what i currently use myself too
just if im going to do it properly, may aswel get the proper kit first time round
Mr Joshua
Member #: 1954
Luton Bedfordshire
Joey you need to speek to Alan at Beachgrove Engineering, that's where I got all my braided pipes made to suite and he gets tapped up for custom components from as far a field as SA..
He will send you the bits or complete pipe with what ever fittings you want.
Own the day
Mirage
Member #: 119
I can supply you anything from the Earls range.
Surely any hose supplier could recomend crimping gear ?
Then you buy their hose and ends. I know Earls can sell crimping tools etc.
As for DIY ends...strictly speaking, Im sure they are supposed to be a MOT fail.
Mr Joshua
Member #: 1954
Luton Bedfordshire
Correct most braided hose with the nylon inners fail the snatch test.
Own the day
