| Home > Help Needed / General Tech Chat > filler help. | |||||||
49 Posts Member #: 4864 Member Northants, England |
8th Apr, 2009 at 12:22:04pm
so i thought i'd work on my car today and try to fill in a hole or 2. only to find that my dad "paul s" (who is away on hols) lost the instructions and google really doesnt help.
8th Apr, 2009 at 12:31:45pm
Golf ball / pea ratio.
8th Apr, 2009 at 12:36:31pm
well its just infront of the rear wheel arch. there has been a plate welded in behind. i'll give it a go. if i F-it up someone else will re-do it. |
1050 Posts Member #: 764 Post Whore Staffordshire |
8th Apr, 2009 at 12:43:46pm
isnt a hole there an mot fail, as it is within 30cm of a suspention mount? |
8th Apr, 2009 at 12:53:23pm
well it went okay. i think. just need to letit set and sand it so its smooth its already startin to set... i'll upload a picture soon. |
8th Apr, 2009 at 01:38:30pm
Dood Grown men dont Huff
On 17th Feb, 2009 Rob H said:
8th Apr, 2009 at 01:43:34pm
On 8th Apr, 2009 Anton said:
isnt a hole there an mot fail, as it is within 30cm of a suspention mount? surely if it has a welded plate behind it that repair would be fine. |
![]() 2102 Posts Member #: 432 Post Whore Swindon |
8th Apr, 2009 at 01:51:41pm
if you treat the 'hardener' as a reaction that speeds up the drying time, that will give you the formular for how much to use.
8th Apr, 2009 at 01:53:17pm
just sanded it down :) looks/feels smooth.
8th Apr, 2009 at 02:11:44pm
now use fine filler over the top of that, gives a better finish imo |
8th Apr, 2009 at 05:01:07pm
On 8th Apr, 2009 PaulH said:
Dood Grown men dont Huff He huffs, he is only 17
He's actually done a very good job for his first attempt. There was a plate welded in behind, this was just a skim over the top to flatten it out. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
9th Apr, 2009 at 12:29:14am
On 8th Apr, 2009 Tom Fenton said:
Golf ball / pea ratio. Im going to try and do my best Vegard impression here. they are the wrong way around for the way he wrote his question..... muhahaha sorry i just had to do it... also worth bearing in mind if its cold i tend to use more hardner. |
