| Home > Help Needed / General Tech Chat > Can I. . . | |||||||
![]() 395 Posts Member #: 3636 Senior Member herefordshire |
9th Apr, 2009 at 04:15:26pm
Hi im new the the turbo mini scene, and i was wondering is makeing a turbo mini engine as simple as just bolting on the turbo and going?
9th Apr, 2009 at 04:47:25pm
In theory, yes - you can bolt all the turbo bits to a non-turbo engine.
9th Apr, 2009 at 04:55:17pm
alright, i have a look
9th Apr, 2009 at 05:22:26pm
the t3 is quite usable and definately will work . the engine can be a 998 ,but to use a t3 you really want a 1275 or bigger ,especially if it has the bigger .36 turbine housing instead of the rarer .25 the metro came with originally , which reduces the lag and the rpm when boost starts . Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
9th Apr, 2009 at 05:31:28pm
i got a 1275 A+ will that make a difference? also what kind of power would a 1275 with a different cam and S/C drop gears produce with either a T3 or a T2? |
9th Apr, 2009 at 05:32:05pm
On 9th Apr, 2009 TurboDave said:
In theory, yes - you can bolt all the turbo bits to a non-turbo engine. Whilst you can it theory, in practice it might not last that long. You can have any two of the following, cheap, power or reliability but you can't have all three. Isambard Kingdom Brunel said:
9th Apr, 2009 at 05:33:54pm
Use the 1275cc.
In the 13's at last!.. Just |
9th Apr, 2009 at 05:36:55pm
if you buy a turbo set up off ebay, your guaranteed to get 200bhp apparently "Turbo's make torque, and torque makes fun"
9th Apr, 2009 at 05:37:34pm
100 will be plenty to beat those saxos round here lol |
9th Apr, 2009 at 05:40:30pm
hopfully the 10" banded steels will take 200bhp then lol |
9th Apr, 2009 at 05:50:35pm
Well I bolted a turbo straight on to my 70,000 mile engine and it's still going strong at nearly 10psi, 5000 miles later.
In theory, yes - you can bolt all the turbo bits to a non-turbo engine. Whilst you can it theory, in practice it might not last that long. You can have any two of the following, cheap, power or reliability but you can't have all three. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
9th Apr, 2009 at 05:54:40pm
On 9th Apr, 2009 wil_h said:
Well I bolted a turbo straight on to my 70,000 mile engine and it's still going strong at nearly 10psi, 5000 miles later. As long as you're not to greedy with power/boost and you're engine is in godd condition, it's no problem. On of the reasons I did it was to disprove the theory that engines just blow up when turbo'd. On 9th Apr, 2009 Rob H said: On 9th Apr, 2009 TurboDave said:
In theory, yes - you can bolt all the turbo bits to a non-turbo engine. Whilst you can it theory, in practice it might not last that long. You can have any two of the following, cheap, power or reliability but you can't have all three. Didn't you change the head to lower the compression ratio at the same time? Isambard Kingdom Brunel said:
9th Apr, 2009 at 05:55:43pm
yes, but only to 9.5 :1 Fastest 998 mini in the world? 13.05 1/4 mile 106mph
9th Apr, 2009 at 06:01:40pm
i would have thought changing the head/cr will have been advantageous, but not essential "Turbo's make torque, and torque makes fun"
9th Apr, 2009 at 06:19:39pm
the engine is going to be fully rebuilt, so it should be tip top lol |
10th Apr, 2009 at 07:14:49pm
so what do i need exactly. . . ( a list of everything i need please) cheers |
10th Apr, 2009 at 07:18:05pm
Have you actually read any of the FAQ and Beginners Tech sections? As a lot of your questions will be answered in there, and to be honest you won't get much help of many folk on here unless you are prepared to do some reading yourself. Once you have done this and come back with some more specific questions then you will get all the help you need.
10th Apr, 2009 at 07:19:08pm
The search button is all you need On 12th Nov, 2009 Paul S said:
Gary's description is best |
10th Apr, 2009 at 07:30:01pm
as above, not being harsh, but as the old saying goes, god helps those who help themselves "Turbo's make torque, and torque makes fun"
10th Apr, 2009 at 07:33:05pm
lol ok no worries ill keep looking, i couldnt find much before |
10th Apr, 2009 at 07:37:39pm
ah, had a look and the answer is NO unless you have big money to change pistons, mod the head, etc lol
10th Apr, 2009 at 07:42:56pm
As most people have said, the answer is YES. But it depends what you want. If you only want a low boost engine then most of the stock parts will suffice. Have a read about Wils 998 Turbo, http://www.turbo-mini.com/62147.html. This is a standard 998 with a Turbo added. |
10th Apr, 2009 at 07:50:09pm
oh right, ive just read that you need to do all kinds of stuff, i just want a low boost turbo mini thats cheap to make |
1050 Posts Member #: 764 Post Whore Staffordshire |
11th Apr, 2009 at 09:44:35am
just remember the old saying...
