| Home > Help Needed / General Tech Chat > Intercooler and piping for this >> | |||||||
![]() 536 Posts Member #: 5449 Post Whore Melton Mowbray |
10th Apr, 2009 at 04:11:27pm
Hi all,
cool, i'll pop over with my tool and some lube, lol 1293 88.8hp 82.2ftlb 17.3 1/4 @ 78 mph Naturally Aspirated (for now) |
10th Apr, 2009 at 05:12:08pm
It is much easier to get an intercooler and make it fit with pipes than get some pipes and find an intercooler to fit.
http://www.twin-turbo.co.uk
10th Apr, 2009 at 05:13:32pm
I think you may find that is an air temp sensor as well.
10th Apr, 2009 at 05:31:41pm
Ok, thanks for the help.
10th Apr, 2009 at 05:48:07pm
Well if you say so, but every map sensor I've ever seen has three connections hence I think its a resistance air temp sensor.
10th Apr, 2009 at 06:18:07pm
I work at a Saab dealership, and I asked the older technicians who used to work on the 9000s and they said its the boost pressure sensor. I had a look on the Saab that I took it off, and there isn't a MAP sensor or an air flow meter. The one on the boost pipe is the only air sensor. On 25th Sep, 2009 mini13 said:
444 Posts Member #: 2885 Senior Member |
12th Apr, 2009 at 05:45:06pm
Am i correct in assuming that is a charge pipe from a Saab 9000?
12th Apr, 2009 at 07:45:59pm
Yes, it was a P reg I think. Whats TD5 intercooling?
12th Apr, 2009 at 08:30:05pm
Landrover TD5 intercooler mate, its mini grille (ish) sized and would fit (kinda) to that pipe of yours like in the pic
12th Apr, 2009 at 09:06:57pm
That intercooler is massive for a mini lol. yeah, looks like that pipe could come in usefull. On 25th Sep, 2009 mini13 said:
12th Apr, 2009 at 09:23:08pm
find an intercooler that you are happy will fit and then look at pipe work will be much easier. the pipe looks very handy and youll probably end up chopping it to use the bends.
12th Apr, 2009 at 09:30:42pm
Ok, will try and find another intercooler that is more suitable. Someone PM'd me today about an intercooler for sale from my wanted advert, so lets hope its suitable.
13th Apr, 2009 at 12:14:26pm
Temp. not Press. then. |
13th Apr, 2009 at 02:20:36pm
