Home > Help Needed / General Tech Chat > Welding Mild Steel to Cast Iron (turbo adapter plate)
Got a mild steel turbo adaptor plate, and want to weld it to a cast iron manifold.
I think Phil has done this when he put a T2 adaptor on his T3 manifold?
Ive tried Oxy Acetylene with mild steel rod but its not taking
A firend of the family suggested using chromium rods in the stick welder, but still doesnt think it will be 100% succesful
Anyone got any tips/advice?
Joe
I'd try and bolt it up if you can, welding to cast isn't always that successful.
If you do try to weld it is nickel rods you want.
no way of bolting this unfortunately, its my mate ben's starion manifold, and theres just not enough meat around the existing outlet
i dont know much about welding anything other then steel so this is new territory for me really
a volvo forum recommended to a guy doing the same thing on an old 240 to use nickel rods in an arc welder, and get the casting cherry red prior to welding, then burying it in sand to cool overnight to prevent it cracking
but there were no posts after that, so i dont know if its duff advice or not?
This works
Nick
Member #: 154
Midlands
i know you can weld up cast with nickel as doodmeister repaired the chambers in my cylinder head with it, worked a treat!
evolotion
Member #: 83
Glasgow, Scotland
i preheat the cast (not to the extent of cherry red tho!! ) and then weld it with a powerfull mig. my turbo manifold is cast iron and mild steel and it hasnt cracked. downpipe was made the same way and it was cast welded to stainless (yes, poor engineering i know)
Edited by evolotion on 10th Apr, 2009.
Denis O'Brien.
madcatminis
Member #: 5327
Dudley, West mids
yeah you've got to heat up cast stuff before you weld it. *smiley*
GaryOS
Member #: 2810
Formally spanner181187
Dublin, Ireland
Are the manifolds cast steel or cast iron? I remember reading somewhere on here that they were cast steel. Could be talking shit, mind
On 30th Apr, 2010 Rod S said:
Gary's description is best
Mine was tigged on, no heating of the manifold etc
Nearly four years ago now i think, & it's still ok. {touch wood ! Lol}
nutter driver
Member #: 47
Not very sunny swanage
ive mig'ed cast to mild on more than one occasion (all turbo related) with no failures....... not that that is any guarantee, but hey.....
fab
Member #: 100
Parisien Turbo Expert
Paris' suburb
second this, mig is ok!
