Home > General Chat > Intercooler blown
alandavies215
Member #: 1844
BURNTWOOD, staffordshire
Hello all
Been out today as it was nice and decided to give the old girl a few beans, well as the title says I blew the end off the r5 cooler that I had on, I don't think the lack of traction over the island helped as reves rose some what
I got talking to a couple of cossy boys down the road witch they have a spare witch will fit at the front for £30 just wandering if this is a bargin or not
Cheers all
30 quid for a cossie cooler or a r5 one?
bit of a bargin if its the cossie one.
lbit late, but, ots of zipties help keep R5 ones together.
alandavies215
Member #: 1844
Hi
It is for a cossy one
Would you keep the r5 with zip ties or change for the cozzy one, he also says he has samco hoses I can have as the pipework is diferent
Ben H
Member #: 184
Melton Mowbray, Pie Country
The R5 one is not that great, the cossie one will be much better. We held our ends on with a big ziptie, but the thing still slowly destroyed itself.
http://www.twin-turbo.co.uk
cossie one! :)
shane
Member #: 1246
Lowestoft, Suffolk.
cozzie one would be better, but if you decide to stick with the R5 one I have an all ally pace one if you intersted, pm me.
Shane
If your sticking with the R5 unit, join two of the longest jubilee clips you can together & strap them around the cooler, this is what I did to stop the end tanks blowing off. Also if you haven't already, remove the thermostat system in the top tank, this will improve flow.
As Ben says, our end caps stayed on, but the core was made of such thin metal that it started blowing appart at the ends.
alandavies215
Member #: 1844
Thanks guys I'll be getting the cozzy one anyway be will let u know anyway
Ben H
Member #: 184
Pardon?
alandavies215
Member #: 1844
I have just picked up the cozzy cooler it's big, it's a test prototype aparently will let u all know if I can fit it in
What Cosworth is this from? I had an Escort one which was huge. Never fitted it as it wouldn't fit with my steel front, inner wings etc.
alandavies215
Member #: 1844
Hello
Not realy sure but it's 23 inches long with the outlets another 2 inches ether side x 6 inches high x 2 inches deep
Had a look if I use 2 samco u bends with what I've got it might fit, will have to cut a little bit more out of the sides at the front but hey
Does anybody know were can get cheep samco pipes from or do I just go to Deamon Tweeks
Thanks
shane
Member #: 1246
Lowestoft, Suffolk.
Silicon hose.com, priced my bay up with sameco then fainted, managed to do all mine for a fraction of the cost, good quality too.
With the IC is it cossy or rs500?
Shane
