Home > 998cc > 998turbo will need turbo distributor?
sheldon
Member #: 1758
Malta
As per title... will the normal A+ distributor workl fine on a 998 turbo conversion?
im not planning to run more then 5psi! on a standard 998cc
1971 Mini Clubman
1982 Mini Clubman Estate - SOLD
1976 Mini Austin or what remains...
Interesting thought. Safest thing to do it install it to give a maximum advance of 25deg. Then advance it bit by bit carefully listening for pinking, if it pinks you'll have to retard it a bit then clamp it up.
It'll be a compromised setup, but at such a low psi you might be able to run over 30 deg, which isn't far off what a high compression 998 A+ runs anyway.
