| Home > Help Needed / General Tech Chat > brake question | |||||||
![]() 1128 Posts Member #: 142 Post Whore Winchester |
26th Oct, 2004 at 11:11:35am
if you use an adjustable brake bias valve do you still need the compensator thingy on ther bulkhead? |
26th Oct, 2004 at 11:18:47am
Nope
26th Oct, 2004 at 11:23:21am
yeah i have a hydralic switch, it seems a bit shite! it needs to go any way i forgt to undo the brake pipe when i dropped the subfarme and engine out and i bent the switch, where can you get the bias valves from?
26th Oct, 2004 at 11:37:43am
You can get a bias valve from any motorsports supplier you choose. e.g. demon tweeks/merlin motorsport anywhere like that will sell you one.
10th Nov, 2004 at 11:25:43pm
hi just got aother question, is it legal to have a bias adjuster in the car, i've just been told it may be illegal?
11th Nov, 2004 at 09:22:28am
Had many cars with valve fitted and obvious pass the MOT so as far as I know legal from that point of view.
11th Nov, 2004 at 10:16:10am
Its legal.
AlexF |
11th Nov, 2004 at 05:40:18pm
hurrah!!!, i have now ordered one
11th Nov, 2004 at 05:46:05pm
mmmmmmm gadgets for cars... i love 'em
12th Nov, 2004 at 09:14:58am
You will probably need to order some adaptors to allow you to use 3/8" UNF flare nuts and 3/16" copper pipe. The adaptors in the picture will almost certainly be for aeroquip type brake lines, that do not use the convex/concave seat as used by solid pipe. If you phone up where you ordered it from and explain how you want to plumb it in (e.g. copper pipe) then they should be able to supply you the right adaptors.
12th Nov, 2004 at 11:12:03am
ok cheers mate
