Home > General Chat > Metro Van Turbo
Right as the old metro van did a good job getting us around europe, apbellamy and I are going to treat it to a rebuild over the winter and hopefully stuff some forced induction in there.
Open to opinions and suggestions as always.
Plan is to replace all the shoddy body panels and fit a Tickford bodykit. Home respray in gawdy yellow as per original and stick a mildy modded turbo lump in there.
This project will be done on an absolute shoestring budget.
So far the specs we have are.
Minispares Stage 3 Head (chambers to be opened up)
STD Metro turbo pistons
Aiming for CPR about 8.6-8.8:1
MG Metro cam
STD Refurbed box with uprated diff pin (no x-pin)
New AP Turbo verto clutch
T3
Cossie cooler (if it can be persuaded to fit in there)
MPI Metro fuel tank (for pump)
v3 megajolt (map version)
Sound alright?
We haven't decided on what boost to run as we don't want to overwhelm the verto clutch so prob not much more than 100bananas anyway.
We have also individualised the rear suspension fitted a turbo ARB and plan on lowering the van slightly and using 175/50/13 tyres.
Hopefully it will look something like this, but a bit less of a gawdy colour, MK 2 front end and metal in place of the back windows.
Lots of room inbetween the front fog lights for a big intercooler...
Mr Joshua
Member #: 1954
Luton Bedfordshire
Thought Standard pistons and rings were like hen's teeth.
Own the day
Minimadmotorman has an engine with a good set in it. They are coming out for some 73.5mm acrolites.
They are but I have a set and if we need more rings you can get them from total seal.
Tickford may be iconic, and may have produced some interesting turbo morors back in the day, but boy their body kits look dated now.
*Sick*
Now now be nice.
lol
It stands out already, we're trying to keep that going....
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Blimey...that looks rough! :(
PS...personal opinion *happy*
On 19th Jan, 2010 wil_h said:
That pic has been photo shopped to make it yellow. Hopefully the van will look better than that...
If you sprinkle hundreds and thousands on shit, it is still shit *smiley*
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Very subtle Paul! lmao!!
giallofly
Member #: 164
The Stig..
Newport Pagnell
Love the idea, not a fan of the body kit but each to their own!
Yellow, the best colour!
JF.
lmao. Yes our van is shit, but in the best possible way.
*happy*
mayoturbo
Member #: 1395
chepstow
I think you should leave it looking like it is now and turbo it, more sleeper
The front end is dropping to bits and the bonnet got damaged when we had a blow out, so it's getting panel work what ever happens.
The Tickford kit is that bit different.
metroturbo
Member #: 989
North Yorkshire
Love the yellow idea and the bodykit. Go for it.
Now that most have you have torn the body design to shreds, any comments on the engine spec? *smiley*
I'm reckoning about 100 bananas is plenty for this car.
You will end up with better off-boost performance if you aim for a higher CR.
If you are not planning on running over 100bhp and you are sticking with the standard transmission you will end up with a more drivable car.
Might be a plan then not to bother opening the chambers of the head much then.
What sort of CR would you recommend?
We have the cossie cooler so the boost can be wound up a bit without detonation being to much of an issue...
A friend of mine has had a fiddle with photoshop and come up with this. Click the pic for it in slightly higher resolution.
Also mk1 turbo the guy who has sorted the tickford kit for us suggests we smooth in the 3 grooves in the bumpers.
1. because the kit has some damage and 2. because he reckons it will look better (i don't know though?)
Edited by John on 27th Apr, 2009.
