Home > Help Needed / General Tech Chat > How do you change calliper pistons?
bigdavea99
Member #: 5898
Hey all
first post on this site, I am converting to metro turbo four pots. Have got everything i need to do the conversion but want to change the pistons and seals. I cant find anything anywhere telling me how to do it. Please help.
Dave
giallofly
Member #: 164
The Stig..
Newport Pagnell
CAREFULLY blow the pistons out with an air line, they do shoot out faST SO AIM WELL!
Clean and refit in the reverse order in which you took them apart.
Use brake fluid as lube.
No rocket science.
Hope that helps.
JF.
Whats the best way to change Dust seals?
I'fe rebuilding calipers, I'd ALWAYS have them bead blasted, and even if there is a small hint of rust on the pistons, I bin them.
The easiest way to change dust seals, is to remove the old ones and fit new ones. So I'm told :)
fook me your a clever lad, next thing will be you telling us the best way to remove pistons is to pump them out with the brake pedal,lol.
Mr Joshua
Member #: 1954
Luton Bedfordshire
That must have hurt.*tongue*
Own the day
Mr Joshua
Member #: 1954
Luton Bedfordshire
If they are not leaking leave well alone.
Like some say if it's not broke it dont need fixing.
Own the day
i think i see that on TMF
Ok so now you are giving advice even though you haven't done it yourself. Thats not like you.
miniminor63
Member #: 672
The oversills police
Oslo, Norway
been drinking Vegard?
Yes, Loads of times!
