Home > General Chat > Rolling Road
Gavin Wakely
Member #: 793
Just had the car set up at Baldwins.
8lb - 122 horses at 4900,
10lb - 144 horses at 5000.
Engine Spec:
28cc Benross worked head
Omega forged pistons
266 cam
Large Charge cooling system
Rest of engine is the usual stuff.
We didn't go any higher on the boost cos the engine hasn't been run in for more than 1/2 hr, and when the car was on the rollers for an 1 hr the exhaust valves were very slightly being pinched buy the guides.
So after a good run in all should be fine, and should be more than capable of pushing some big figures.
It drives fantastic as a road car, so would like to BIG up the BENROSS for his quality work which shows in a bloody good engine with good figures :)
mans turbocharger or gay supercharger?
geuss turbo as two diff boost fugures and only 1hr of rr time :)
well Gavin sounds good. your braver than me mate i normaly only go on rollers for setting up and have any power runs once 500 miles is covered :)
Very supriced you have gone turbo / supercharged TBH *wink*
Edited by Miniwilliams on 23rd Apr, 2009.
stefaz
Member #: 1656
stoke-on-trent
Sounds like good figures there Gavin...hope you can get it run in quickly and get it back on the rollers for some even bigger numbers
Gavin Wakely
Member #: 793
Matt The turbo set up is in my other project, not the speedster, that will stay N/A for a while yet.
I wanted to get the engine set up straight away, as I was concerned about it misfiring & over fueling and generally running very bad. Aswell as a lack of knowledge / confidence with turbos.
That's a nice subtle looking mini, not quite sleeper. Good power too *smiley*
Yep they are some good figures. Even for Baldwins Rollers.
Good stuff. There's info missing though, cc? Turbo type? Any clues?
ministef1
Member #: 1791
Cranleigh, surrey
does that aerial pick up radio1 in japan?
"Cars are a lifetime of pain"
Looks like it has the obligatory oil leak. :)
Scruffy
Member #: 328
Seaford Rise, South Australia
What engine was in it when you went to Holland in it Gav?
How about a resto thread for the speedster?
Edited by Scruffy on 24th Apr, 2009.
On 5th Sep, 2011 Vegard said:
well your other projec looks sweet! are i see now, as i know your not to keep on the blowers from your comments in the past, but if your keeping the roads n/a for now i see what you've done*wink* Any thing i can feature??? lol.
Sounds good to me.
good figures gav
Rick
Gavin Wakely
Member #: 793
1312cc and good old T3
Gavin Wakely
Member #: 793
Just a standard metro turbo unit.
Just starting the strip and rebuild of the speedster so might do a build thread.
well gavin, i am so glad you are pleased !
get the boost up some more on the RR and hang on for some larger power figures
you will be pleasentley suprised.
the head will produce some intresting figures *Yes* *Yes* *wink* *wink* *Clapping* *Clapping*
Gavin Wakely
Member #: 793
Feature would be sweet Matt, the MiniMag have been supposedly trying to organise a feature for a while but nothing yet 8-)
