Home > Technical Chat > Turbo sizing
greymini78
Member #: 2408
surrey / ewell area.
Hi all does anyone know the a/r etc for a montego turbo as i have been offered one for a favour its got a t2 flange. might be off a diesel?:)
Montego T2 must be the Perkins Prima unit - which I recall is a 0.35 AR turbine and a 50 or 55 trim compressor...
Are you sure it is T2 flange?
The Montego Turbo diesel is a 4 bolt flange, .35 exhaust .55 compressor iirc.
greymini78
Member #: 2408
So possibly a t2 style ? sorry limited experience with turbos. Just wondering as i will be using the mirage set up.
It is a T2, yes.
greymini78
Member #: 2408
Cheers Phil didnt know if it would be worth trying or not. ill keep u posted about bits.
greymini78
Member #: 2408
p.s This one says .046 a/r,Im guessing this wouldnt be to far off the sort of sizing i need for 1293 with an mg cam?
If it has the 0.46 turbine, that is actually pretty good for a 1293. I must be having brain fart however as i was sure the Prima was a 0.35 A/R.
Might be worth measuring the compressor to be sure, but if it has a 0.46 turbine, I can't imagine it would be less than a 55 trim however.
