Home > Help Needed / General Tech Chat > Metro Help
blake12345
Member #: 3103
Hey, Ive been given the chance to buy a metro turbo engine. The guy who is selling it has used the turbo somewhere else but is willing to throw in a weber that is jetted for a 1380. So my question is will a turbo engine run alrite with a weber on it?
Also i know it depends on heaps of things but if an engine is rebuilt some years ago and has only been driven around the block a few times and just started here and there should it be rite or will it need another rebuild eg. gaskets etc. ?
Thankyou
Blake
Ben H
Member #: 184
Melton Mowbray, Pie Country
This has been covered many times, search. But as I am nice, the engine will run fine N/A, can't vouch for the webber though.
The engine will be a bit of a lottery really. Impossible to say.
http://www.twin-turbo.co.uk
blake12345
Member #: 3103
Yeh i thought it may have. I did a quick search but i couldnt find anything. but yeh well if itd run alrite N/A then thats pretty much what i wanted to know thanks heaps
might want to find out what the compression ratio is on it. if its low then it might be worth sorting another head for it to bring it back up for N/A form.
at least then if you want to go turbo you can slap the other head back on and you have the a decent compression ratio for it.
Don't think of a turbo engine as special, they are basically a 1275 motor with sodium exhaust valves and a different cam (if it's all standard).
The Webber jetting at a guess will be all wrong.
Why not just sell the Weber on eBay?
It should make you enough cash to buy the turbo gear, or at least help somewhat.
Mr Joshua
Member #: 1954
Luton Bedfordshire
someone correct me if I am wrong but all he has there without the turbo is 1275 mayfair lump with some very nice valve gear and nice crank.
Own the day
Pistons are different as well.
blake12345
Member #: 3103
ok kool thanks for the info. So the metro engines have stronger internals?
Mr Joshua
Member #: 1954
Luton Bedfordshire
The turbo engine does and runs at lower CR.
Own the day
Lower than what?
The standard Metro turbo CR is 9.4:1. Same as a lot of standard N/A A+ 1275 engines.
Ben H
Member #: 184
As covered a million times the internas are standard too. Read this if you want the full story:
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=4724
