| Home > 998cc > Pocketed block VS Turbo??? | |||||||
![]() 67 Posts Member #: 5547 Advanced Member Ayrshire, Scotland |
30th Apr, 2009 at 03:29:00pm
Ok after having my mate i was going to be building the 998 with went awol, i was going to just pokcet a 998 block n forget the 998 turbo... but i have a notion to try it...
30th Apr, 2009 at 03:50:34pm
Well, of course a pocketed 998 block will give much more power than a turbo. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
30th Apr, 2009 at 03:52:32pm
pocket the block to fit a 12G940 head than strap a turbo onto it, job done..
Yes i moved to the darkside |
30th Apr, 2009 at 04:06:04pm
30th Apr, 2009 at 04:18:37pm
On 30th Apr, 2009 Brett said:
pocket the block to fit a 12G940 head than strap a turbo onto it, job done.. that's kind of what i was thinking...was something else i was goign ask ask, if u could pocket a 998 block yet still run the 998 turbo set up... |
30th Apr, 2009 at 04:24:52pm
If your going to turbo a 998 by pocketing the block don't go silly with the valve sizes. Mahoosive ones arent needed. If something is worth doing, it's worth doing half of. |
30th Apr, 2009 at 05:07:16pm
no no, i'd just pocket it to suit a 1275 head... |
30th Apr, 2009 at 05:10:26pm
ruffle translates as:
On 30th Apr, 2009 Bert said:
Ok after having my mate i was going to be building the 998 with went awol, i was going to just pokcet a 998 block n forget the 998 turbo... but i have a notion to try it... whats the pros and cons between them? I can see that a turbo will probably cost me a fair bit...but the pocketed block might not be as bad on price...but i'd just do it over a longer period... what u think? In answer..... A standard 998 with a well sized turbo will produce 80 - 90 hp and probly the same in torque. A very well built 998 N/A with a pocket block and well ported big bore head will probly make 60-70 hp but need to rev to circa 7500 rpm meaning, you will need hardened crank, light weight flywheel propper carbs, etc expensive, Have a look at Wil's turbo 998 as far as I know it practly standard and makes nice hp for small money. Edited by PaulH on 30th Apr, 2009. On 17th Feb, 2009 Rob H said:
30th Apr, 2009 at 11:50:03pm
Paul is your middle name Inigma Own the day
1st May, 2009 at 12:06:27am
Nope but, I think its should be Jobe, and my first name patients of On 17th Feb, 2009 Rob H said:
6th May, 2009 at 11:02:57am
Sorry been busy for a while there
6th May, 2009 at 11:08:40am
On 6th May, 2009 Bert said:
Sorry been busy for a while there so if i pocketed the block would i be best fitting a T2 or T3 Turbo afterwards? Well, that depends if you want to turbo it or not... On 13th Jul, 2012 Ben H said:
6th May, 2009 at 12:02:32pm
Not being funny, but this is a silly question. How can pockets in block possibly affect the type of turbo that is suitable?
Sorry been busy for a while there so if i pocketed the block would i be best fitting a T2 or T3 Turbo afterwards? Fastest 998 mini in the world? 13.05 1/4 mile 106mph
