Home > Technical Chat > Kad Front Plate Thickness
Tareq
Member #: 970
Bahrain
Hi, Was wondering if anybody knows how think the alloy front plate (on front of engine block) used on the KAD16v conversion is.
mine's a long case head, , so doesn't have that plate,
Tareq
Member #: 970
Bahrain
Ok. Thanks.. Didnt know that there were different types... You wouldnt have a pic of that would you?
I'll sort you some pictures later :)
Tareq
Member #: 970
Bahrain
Cheers Sprocket
Tareq
Member #: 970
Bahrain
I'm liking the belt tensioner/idler pulley setup on the Kad.... Would anybody have a clue what car they would be off?
Scruffy
Member #: 328
Seaford Rise, South Australia
Ford
On 5th Sep, 2011 Vegard said:
On 30th Apr, 2009 Scruffy said:
Ford
pinto,
Tareq
Member #: 970
Bahrain
Ford Pinto?
Like the one in this pic? (Thanks to the person I nicked it off)
i don't recognise that tensioner, unless its like my kads own design with an excentric middle, not ford,
but i think its Dan websters old engine,
Tareq
Member #: 970
Bahrain
I've been searching the net.. Might look like a Cosworth YB tensioner.
Will have to check with my mate as he has a Cossie... Not many of those around this part of the world.
Maybe of the standard 16v Ford Sierra engine aswell? I've seen them like that on a few websites. Can't figure out what idler pulley that is either.. Wondering if the tooth profile on it would match the honda gears.
Tareq
Member #: 970
Bahrain
Maybe like this one
http://cgi.ebay.co.uk/Ford-Cosworth-YB-Cam...%3A1%7C294%3A50
thats similar to or the same as fitted on the DON.
Tareq
Member #: 970
Bahrain
The the DON have the idler pulley aswell?
carl talbot
Member #: 1323
I thought the early KAD ones were Pinto
later ones [ eccentric ] were Vauxhall
Some one on this forum may recognise some of these pictures*happy*
Just realised the first pic is actualy the JKD plate *hehe!*
Edited by Sprocket on 30th Apr, 2009.
I recon that the seals in those plates are Ford *happy*
I use the Ford Fiesta 1.25 zetec cam seals, 52mm OD 38mm ID and they fit nicely between the cam/ jackshaft triangular plate bolts *happy*
Interesting information, ever since I got a set of honda cam pulleys, I've been thinking of doing my own scrap heap challenge style K-head conversion. I'll probably realise soon I don't have the skill or tools to do it though!
This is my effort, the new design new *happy*
not an dler , but the one you show will work as a tensioner as it has an excentric mount, as is fitted to DON on an early head,
completely different belt arrangment to the ones sprocket has posted.
carl
Tareq
Member #: 970
Bahrain
Sprocket.... Fantastic pics
Thanks for the info Carl..
I'll check my mates cossie's pulleys this weekend.
engine porn!!! *happy*
Tareq
Member #: 970
Bahrain
I think the tensioner might be of the YB Cossie and the Idler pulley is of the early c20xe.
