| Home > General Chat > Clutch Judder | |||||||
365 Posts Member #: 1211 Senior Member Working up the BHP ladder. |
1st May, 2009 at 07:44:13pm
Just installed my ultra light flywheel set up with a new plate. The flywheel and backplate have been machined because the drive faces were chewed up from a paddle clutch. The faces have been flattened in a lathe and the turrets on the backplate macnined accordingly.
2647 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
3rd May, 2009 at 10:01:29pm
I had a panic when I fitted mine a month or so ago was doing the same, A few miles on mine has now cured it, also slipped it a few times while on boost when stationary.
3rd May, 2009 at 10:33:20pm
Try doing a few standing hard starts with the clutch really slipping it.
6th May, 2009 at 10:03:44am
Nope!!! Tried it this morning and it seems FOOKED. No clamping load atall, it slips just driving uphill at 30mph.
6th May, 2009 at 10:11:36am
really bad judder would suggest poor machining , in so much that the plate is no taking up evenly,, are the three bolts all tight,if ones loose it will judder.
6th May, 2009 at 10:19:26am
Ian at Avonbar machined it and considering the whole thing came from there in the first place in absolutely screwing!!!
