Home > Help Needed / General Tech Chat > Vacuum pipe size
Guennie
Member #: 2328
Nr Newmarket, Suffolk
Hi guys,
I've done a search but can't find the answer i'm after!
I'm about to order a couple of meters of silicon vacuum hose for, dump valve, megajolt, boostgauge etc, but am unsure what ID size to get. Can you guys recommend the correct/best size i should be using?
Guennie
100% BMW Free
jamz
Member #: 2292
Tool
Herne Bay, kent
i think its 4mm? but wait for some to answer who defo knows
cant beat a good blowout.
I use 6mm
Guennie
Member #: 2328
cheers guys. so it seems that there is no set size. It's more down to personal choice.
100% BMW Free
It really depends on the stub diameter of the bits you are connecting to.
6mm is a common stub size for things like dump valves, boost control valves but not everything will be 6mm.
Check your Megajolt for example - on Megasquirt it's only a 4mm stub, Megajolt may be the same....
