Home > Show Us Yours! > OT Head gasket
After the headgasket going in the carpark at riv run i have started the repairs.
Started off the day by ordering my parts ready for 2moz. started stripping down the 106 ready for the head gasket to be replaced and doing cambelt at the same time. just pictures of what i did is some people are interested the headgasket failer was so so slight it took me 10 mins to find where it went lol.
Started off by taking the front bumper off to do a few deer damage repairs and to get to the rad mounting points to remove it, as you can see the coolent wasnt looking so great...
next i started stripping the anoying bits you have to remove to get get the head off easily
Next i jacked up the car so i had some more room to get the bottom pull off and get at the cambelt
Drained the oil out and removed the oil filter, luckally no coolent here
Once the engine mount was off and the cambelt covers were off i set about timing the engine up and getting the cambelt off.
Next was to undo the headbolts unplug the last few bits and bobs, remove the rockers and remove the head to inspect the gasket
to me it seems as though it started to go between 2 and 3 cought it just in time before it did anything major, there was only mix of oil in the coolent no coolent in with the oil.
enjoy paul.
Unless it's a camera artefact, from the 3rd and 4th photo back from the end, it looks like all four cylinders were failing (top left on photo of each one)
Carl
Member #: 95
liverpool-on-sea
your bound to get head gasket problems running these hi performance machines.
I suspect that is for valve clearance *wink*
LMAO!
im not sure either each top of the piston had the clean spots on them they are flat tops so im not sure whats going on there... will have a proper check 2moz.
Its clearance for the valve and the clean spots on the tops of the pistons are as a result of the fresh fuel/ air charge being drawn in. Petrol is a good cleaner you know *wink*
thats good then, i was atarting to worry for abit, well for the hole time it took to post the reply i cant aforde it to be more than the hg lol :)
Looking again I have to agree as they are all identical and match the position of the (presumably inlet) valves in the head.
Strange design though - I wonder if the same head is used on something with slightly bigger bores.
well the head has now been skimmed still waiting on my cambelt kit though. anyway the head is now on and tightend up 20nm 90deg x 3. i have had enough of french cars 2day as all i want to do now is burn it. just a few pics this time.
evolotion
Member #: 83
Glasgow, Scotland
how can you hate it, the only engine easier to do a head gasket on than that is an a-series. and even then theres not much in it *tongue*
Denis O'Brien.
Ollie
Member #: 1380
how much was it to get skimmed mate?
miniboo
Member #: 2253
Las Vegas, Brit in the States
before you put the head back on did you put a mini HG on the head to check ????
Would have to agree, I've done these and they are a piece of piss...............
head to get skimmed was £30 not to bad imo, as for the doing it i didnt mind doing it at all it just pissed me off having to wait for parts then getting the wrong bits sent to me having to wait ect ect. got a few pics of the last parts that are now done was it back running again, done 40 odd miles now and all is going well :)
PICS
A few of us messing around
Edited by Paul R on 11th May, 2009.
i popped over yesterday to see how you were doing but no-one in
glad you got it sorted
oh cheers mate should have given us a call, me ollie and chunk went over to our garages after we had finished with the 106, we were probably there when you poped over
talking of garages i need to pick up that lump sometime
