Home > Help Needed / General Tech Chat > Seized nuts and studs in cylinder head.......Damn them
Graeme
Member #: 264
Southampton
Im currently rebuilding an MG Turbo unit but have become stuck...
Of the 5 nuts and studs holding the exhaust and inlet manifolds to the cylinder head, ive managed to removed 3 of them. The middle 2 (the most inaccessable) wont budge, Ive been using WD40 and leaving to soak but still no joy. Its a shame my angle grinder cant get in there! Any ideas?
Thanks
Yes, Im getting there.....
www.itsmuckingfagic.com
Heat it until it's red!
nutter driver
Member #: 47
Not very sunny swanage
a decent six sided socket a try again, if that doesnt work the try a decent six sided socket a size smaller than they are supposed to be, and knock it on. never failed me yet!
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
Try using diesel instead of WD40... it works better!
alex
AlexF
Graeme
Member #: 264
Southampton
Thanks guys, but still no joy. So i resorted to the hacksaw, took a while but at least i got the damn thing apart!
SumpNut
Member #: 28
i use plus gas, its brilliant on seized bolts
adam1330
Member #: 238
essex
whats plus gas?
i've managed to snap one of the studs that hold on the turbo elbow!!! got enough thread to get a pair of mole grips on it but it wont budge!!!
Nick
Member #: 154
Midlands
hmmm, i got one of them to do on me spare turbo. i planned on heating the turbo up with a blowtorch then dropping some cold water on the stud. that method worked a treat when we snapped a subframe bolt off.
Plus gas is like WD40 but is a lot better as its meant for releasing seized things.
i drilled mine out and helicoiled it. if you do that they will never seize again. its the method we use on our gas turbines as things get hot.
Kean
Member #: 341
aka T2clubby
South Staffs
Be carefull with that on the casting dude its more likely to fracture with the sudden change in temp
adam1330
Member #: 238
essex
done it!!!
heated it with a blowtorch!!
easy peasy...
Told you!
Dr. jinG
Member #: 368
Roseville, CA (USA)
Wish I'd read this earlier! My resolution was to weld a nut to the stud, let penetrating oil soak in a few days, then use an impact gun. Worked like a charm...
1967 Cooper 's' Turbo build @ www.drjing.com
