| Home > FAQ / Knowledge > Millers CVT 20w50 | |||||||
![]() 370 Posts Member #: 181 Senior Member Chard, Somerset |
7th May, 2009 at 09:46:01am
Just spoke to Millers to get the ideal and top temperature for their CVT 20w50 oil which most of us use. The guy in the tech department stated that for optimum oil performance it should be between 90-100 degres C and the the temperature at which this oil begins to break down is 130 degrees C. Some of you may have been aware of this but I thought it might be an idea to get the figures direct from Millers.
7th May, 2009 at 10:34:29am
Good info, that why I'm suprised so many people here run an oil coolers, I had to remove my large oil cooler and fit a smaller oil cooler and place it away from direct air flow.
7th May, 2009 at 10:36:37am
Can't see owt jim. If something is worth doing, it's worth doing half of. |
7th May, 2009 at 10:36:41am
Doh, screen shot will not attach, try here
Edited by Jimster on 7th May, 2009. Team www.sheepspeed.com Racing
7th May, 2009 at 10:53:11am
I am running without an oil cooler on both the high revving 1191 cc engine (70.2 mm stroke) and on the screamer 133 (at the wheels) hp NA 16V engine. None of these have ever seen more than 110 degree oil temp. and that was after 12 laps at a very fast track where I had more than 6500 rpm almost everywhere. Edited by miniminor63 on 7th May, 2009. |
7th May, 2009 at 11:17:59am
Where where you measuring oil temp jim?
AlexF |
7th May, 2009 at 11:34:03am
I take my oil temps behind the oil filter housing, so IMO this is the temp of the oil going to the bearings. Team www.sheepspeed.com Racing
7th May, 2009 at 12:13:33pm
iiiiinteresting.
7th May, 2009 at 01:43:04pm
I've not had an oil cooler fitted for years now. Simply because according to the gauge, I don't need one. |
