Home > Help Needed / General Tech Chat > when my mini comes onto boost it cuts out. either runs out of fuel or too much???
psimini
Member #: 6070
when u rev it and boost comes on it cuts out or dies out of rev. like it would when theres fuel running out. what might the rpoblem be. im using a holley 3-9psi regulator. it doesnt have vaccum on it for one and also using a na hif44 metro carb with turbo needle and jet..???? help
na engine + turbo + boost = ya hewwww
PaulH
Member #: 2340
Dublin Ireland
Change the carb to a turbo one, and change the presure reg to rising rate
This is the basic of the basic get serching it all here
On 17th Feb, 2009 Rob H said:
You need the turbo specific fuel pump and reg. The NA carb can be made to work but needs modifying.
And if you need to be using the Metro Turbo plenum
psimini
Member #: 6070
WELL IVE GOT A TURBO JET ANd needle. possibly the regulator. its a rising rate holley but doesnt have the vaccum nipple to sense boost. maybe this is why. fuel pump is plenty of grunt
PaulH
Member #: 2340
Dublin Ireland
how can it be rising rate with out a vacuum/boost nipple ?
Rising rate is nothing to do with referencing boost or vacuum.
Rising rate is when the pressure rises with increasing flow. Something the Chavs use on otherwise standard cars to increase fuel flow at the top end.
PaulH
Member #: 2340
Dublin Ireland
very intresting Paul, so what is the name for the turbo type reg boost sensing reg ? or is there another name for it :)
power boost valves they call em i think
Carb shouldn't be a problem if you are using the metro turbo plenum and have the right gasket with all the right holes in it.
Pressure reg needs to be boost sensing
An interesting point about a misused term (I often call the proper ones "rising rate" myself).
The technically correct term would be a "differential pressure regulator" (because it maintains a constant difference between fuel pressure and the manifold pressure) - but how often do you hear them called that ???
PaulH
Member #: 2340
Dublin Ireland
thanks Rod taught I was going mad I have always called them Rising rate ( now obviously incorrectly) but like you say everyone I have every talked turbo with have always calledd them presure regs full stop.
Rising rate has nothing to do with flow.
The reg flows its maximum at the lowest engine outputs.
Rising rate does refer to the reaction between intake pressure, and fuel pressure.
Even n/a regs are referenced. So they will maintain a lowish pressure level when vac is applied...but as its withdrawn, FP will not increase linearly as it would with a 1:1 reg.
By rising rate..they mean it isnt 1:1 ratio
Stevie is right.
My description is a little incorrect. The rising rate regulator dumps more fuel in when you stomp on the throttle, but returns to normal operation under cruise conditions.
psimini
Member #: 6070
ok so really i need the pressure sensing regulator thats 1:1 ratio and has the vaccum sensor nipple. yes???
