Home > Help Needed / General Tech Chat > Part throttle OK - Any more and it bogs down?
Went out for a short drive this evening, and the above happens. Part throttle works OK, and it comes on boost, but any more than that and it just bogs down and goes nowhere.
The history of the car:
1293cc, T3, Dizzy + Boring old carb.
RR'd at Baldwins, then used daily for 1 month - then taken apart and sat in bits for 2.5 years. Now back together.
Starts fine, and using the choke makes no difference (altho does make a difference to tickover and the initial small press on the throttle).
So, any ideas?
-a
chinlesswonder
Member #: 1192
In the garage......again!!
timing
133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
Shakespear RWYB 14.995 91.83mph
richminiturbo.
Member #: 719
Horndean - Near Portsmouth
As above Alex.
Checked the dashpot oil? Valve clearances, fuel pressure?
I have checked none of the above - I am a total numpty when it comes to this stuff. Will get the Haynes out *wink*
richminiturbo.
Member #: 719
Hehe me too!! probably shouldnt take my advice actually, anyway take the dashpot off the top of the carb with the three screws. undo the plastic nut on top and drain all the old oil out thats in there.
You only need to put oil into the "tube" the dasphot piston goes into. Use a funnel or something to get some oil in there, dont need to fill it all the way to the top, just so that you feel decent resistance when pushing the piston back in ooerrr.
I use 20w50, but my car doesnt work so you probably shouldnt do anything i've just said.
LOL!
I'll just take it over to AlexF somewhen *wink* Much easier.
has the old fuel varnished up in the carb?
it's got fresh stuff in it atm.. but it did have stale shit in it for a long time...
Oh alex
Undo the plastic screw on top of the carb and fill it up to the top of the round thing insude it with 20w50, and reassemble
lol. cheers, will give it a try...
Yep, dashpot oil.
psimini
Member #: 6070
if you can make sure the piston inside carb is moving freely. it musst be dead square and a smooth slide... most likely dashpot oil anyway.
na engine + turbo + boost = ya hewwww
I take it you have MOT now
Paul
Nope. Not being re-tested till next week now :(
Pottsy
Member #: 843
Stoke-on-Trent. Duck.
Long shot as everyone's suggesting carbs and this could be a red herring, but I was scratching my head a few years ago on this;
"crushed" air-feed ducting to the turbo. OK part throttle but was restricting the airflow at anything above half throttle. Thought it was fuelling at first, turned out to be the pipe was kinked badly. "Airing" rather than "fuelling" suppose you might call it (though still technically fuelling...)
It's an easy-ish check to make (if you can get your head down there), even just to rule it out.
Dave.
good thought, will check that too.
I havent bothered to get the car yet, so havent checked any of this
Glad it's not just me...
On 11th May, 2009 AlexB said:
II am a total numpty when it comes to this stuff.
Has making babies destroyed your man brain?
Dear me.....
