| Home > Help Needed / General Tech Chat > t3 hybrid turbo | |||||||
492 Posts Member #: 3684 Senior Member wisborough green west sussex |
12th May, 2009 at 06:01:42pm
Was just wondering if a t3 hybrid turbo for a s1 rs turbo would work on my turbo lump? ie would it fit my metro manifold? could i just bolt on and drive away? |
![]() 367 Posts Member #: 1643 Senior Member West London |
12th May, 2009 at 06:44:05pm
It would, but it would be horrible to drive. Lightweight racer coming soon. |
12th May, 2009 at 10:28:38pm
However, a standard S1 RS Turbo have been proven successful in Minis. On 13th Jul, 2012 Ben H said:
12th May, 2009 at 10:48:56pm
Not laggy no? Lightweight racer coming soon. |
13th May, 2009 at 07:39:52am
i guess by the sounds of it then its a no go and i should try another option, thing is i dont want to spent loads of a turbo!. |
13th May, 2009 at 08:50:41am
Find out exactly what spec it is, whats been done to it.
13th May, 2009 at 08:55:09am
turbo teqnicsuse a rs exhaust with a metro inlet housings for there straight swap metro turbo's eg instead of a .25 they use the .36 ar exhaust thats what i use it comes in at 3k instead of 2.5k plus bag more ponies up the top always looking for them bigger bunches of bannanas |
13th May, 2009 at 09:36:33am
How much are they these days hoggy? If something is worth doing, it's worth doing half of. |
13th May, 2009 at 10:28:18am
That's what i have on mine with a 360 bearing, think i paid around £300 exchange. |
13th May, 2009 at 10:37:10am
Hmm.
31st Aug, 2009 at 08:25:48pm
sorry to bring up a old post but....
My build thread..
31st Aug, 2009 at 10:07:15pm
It will need the metro wastegate and exhaust elbow fitting. The core will also need rotating so the oil feed and drain will be in line with the block. The compressor housing also needs lining up so it suits the pipe run for your intercooler piping. I also made a actuator bracket as well. So no not really! It will fit too the standard exhaust manifold though. Ron |
1st Sep, 2009 at 08:57:31pm
cheers mate
My build thread..
![]() 3756 Posts Member #: 1709 I like granny porn. LONDONSHIRE |
1st Sep, 2009 at 10:56:20pm
On 13th May, 2009 turbo hogster said:
turbo teqnicsuse a rs exhaust with a metro inlet housings for there straight swap metro turbo's eg instead of a .25 they use the .36 ar exhaust thats what i use it comes in at 3k instead of 2.5k plus bag more ponies up the top i did it the other way around, used the rs comp housing on the mg ex housing, real nice and mad good power On 2nd Oct, 2009 Vegard said:
I bet my first wank came quicker than your first mini turbo These new modern turbos with their quick spool up time, would make the competition harder. On 15th Aug, 2011 robert said:
phew!!! thank you brett for smashing in my back doors .( not something i imagined writing... EVER) |
