Home > Beginners Tech > Oil thrower
Mr Mini
Member #: 346
Portsmouth
Hi can anyone tell me whether the oil thrower is necessary on a K series? Being a dry belt setup?
Cheers.
1310cc TWINK - T Conversion
Is there any oil to throw there?
Mr Mini
Member #: 346
Portsmouth
Its this plate here:
There are no mechanical parts within the cover, as its a dry belt setup, but just concerned whether it would reduce or prevent any possible oil leakage through the rubber seals?
Can you get away with blocking off the oil supply to the area?
