Home > Help Needed / General Tech Chat > K1100 head gasket set
pinkyandnobrain
Member #: 2588
Pretoria South Africa
Where can I get hold of a set ?
I asked my local BMW dealer but there price was ridiculous !*surprised*
Couldnt seem to find anything on the net either but I might just be really crap at google-ing stuff....
Dan
"Try to take over the world!"
Mr Mini
Member #: 346
Portsmouth
Motorworks may do.
1310cc TWINK - T Conversion
philc
Member #: 1346
bromsgrove
sc may also
motorworks are your best bet for a standard gasket. If you're not going drydeck then you'll have to use a bespoke gasket like the copper specialist components one.
pinkyandnobrain
Member #: 2588
Cheers guys !
Found a set at motorworks, just finding out about the shipping before I order.
Matty I am going drydeck so a standard one should work.
Dan
If your dry decking why don't you relocate the studs and use a BK450? Much cheaper if you have to replace a gasket. *wink*
pinkyandnobrain
Member #: 2588
Minimad that is a option but I want to line up the bore spacing with the head so I think the beemer gasket will work better.
Im also very much in the planning stage at the moment so your opinions and suggestions are much appreciated
I would definately be talking to Sprocket.
His conversion looked almost like it should have come out of the factory. I'm also fairly certain he used the BK450 and regularly tops 8k rpm
I use a BK450 on my 16v, no problems with over 30psi boost.
The BMW gasket is 6cc and only good for max +20 overbore, only if you offset bore the outer cylinders and move the head forward to line all the cylinders up with all the head chambers.
Not so bad using the BMW gasket if you are turbo charging it, but if it NA, you could do with either running flat top pistons or a posative deck hight.
There you go the UK pioneers have spoken one for N/A one for F/I and they both use the BK450
Edited by John on 14th May, 2009.
pinkyandnobrain
Member #: 2588
Cheers once again lads !
So BK450 it is.
What bore size are you going to use.
If you line up the bore with the chambers in the head, any available gasket including the BK450 will only be able to take a max +20 bore. Where as, if you were to leave the bore spacing as a normal A series, you can use the bk450, Cometic and Specialist Componets gasket up to a 73.5mm bore
Edited by Sprocket on 15th May, 2009.
pinkyandnobrain
Member #: 2588
Spox im planning on a 73 mm bore.
My original idea was to use a custom copper gasket but I havent been able to find the right material.
The main reason I wanted to line up the bores is because I was worried that the valve cut-out might come too close to the edge of the piston crown, but all the photos ive looked at of the cut-outs are on +20 or so pistons so I will probaly be ok with the bigger pistons.
So I think I will stick to the standard bore spacing and go with the bk450 and just make sure the cut-outs are perfect.
P.S Is the bk450 the standard turbo gasket ? Sorry for the ignorance but we never got the metty turbo here !
Yes. :)
pinkyandnobrain
Member #: 2588
Cheers Phil !
