| Home > Help Needed / General Tech Chat > cooling | |||||||
216 Posts Member #: 370 Reads "my mates" max power whilst wearing my Mrs's underwear |
1st Nov, 2004 at 01:37:41pm
hi all, need some help with finnishing my motor off, i havent got much to do the engine starts yipee, and i've finally got my exhaust clamp on lol |
1st Nov, 2004 at 06:33:06pm
just connect up as per the mini with a mini stat (with a few holes drill in to act as bypass) mini stat housing, then connect that to the top of the rad, the L shaped hose with an extra takeoff between the bottom and the pump then the heat inline with the takeoff on the corner of the cyl head (hope you drilled this out before fitting the head) and the take off on the bottom hose.
3rd Nov, 2004 at 05:00:39pm
i havent drilled no hole in my block lol |
3rd Nov, 2004 at 05:44:35pm
Not the block, the cylinder head. Have you drilled the heater take off out ? On the left hand side at the front.
3rd Nov, 2004 at 07:59:37pm
head ideally needs to come off so you can get the swarf out but you may get away with just drilling it then flushing it with the water pump off and no connections on. |
4th Nov, 2004 at 10:27:05am
yeah the head i havent drilled any holes...
4th Nov, 2004 at 01:27:54pm
On 03/11/2004 19:59:37 iain said:
head ideally needs to come off so you can get the swarf out but you may get away with just drilling it then flushing it with the water pump off and no connections on. Well, debris will fall straight down in the block if this is done. Remember the eight holes at the front of the block/head. These are big enough for crap to pass. On 13th Jul, 2012 Ben H said:
4th Nov, 2004 at 02:16:35pm
What i mean is why do i need to drill a hole in the head, it didnt have this extra hole when in the metty, so can i do with out this hole ? lol all this talk of holes hehe |
Forum Mod 1140 Posts Member #: 93 Post Whore Near Lincoln |
4th Nov, 2004 at 05:59:15pm
metro didn't have the extra holes as it had a pretty huge radiator in comparison to the mini, plus the engine bay was a fair bit bigger
10th Nov, 2004 at 09:11:59am
well i've deciced theres no way im taking the head off or the motor out to drill a hole, so will this work , 2 core rad, samco t-piece hose on the bottom and top hose and run these to the heater |
10th Nov, 2004 at 04:23:38pm
if your on about plumbing in your heater matrix you could get a later two piece thermostate housing off a mini as the bottom piece has an outlet for the heater. mine had one on it was a '93 1275 carb model no longer a series, but still 1.3 turbo.
![]() 1014 Posts Member #: 238 Post Whore essex |
10th Nov, 2004 at 06:13:57pm
thats how mine is running, with the two piece thermostat housing. stays cool.. although i do have the wing mounted fan just incase the temp does creep up! ““A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster.”” - Jeremy Clarkson
10th Nov, 2004 at 06:54:02pm
Go and buy one of those 'magnet on a car aerial' things. Drain off the cooling system.
is this Essential ?
