| Home > General Chat > Head & Valves | |||||||
15th May, 2009 at 07:14:51am
Took my head apart this week, just wanted any thoughts to whether the head could have anymore work done.
15th May, 2009 at 08:28:53am
Those inlets are pretty coked up. What cam are you running ? Was it smoking at all ? If you do get new guides fitted, fit some decent ones that are properly bullotnosed from where they enter the port.
15th May, 2009 at 02:50:24pm
Cam is VP3C, yes somking, using up oil. Yes N/A, I think 37-31 |
15th May, 2009 at 04:24:50pm
re phils advice, i would replace all the guides and seals
16th May, 2009 at 08:16:30am
this is a n/a engine.
Edited by philc on 16th May, 2009. |
16th May, 2009 at 09:46:26am
Have someone in the know to check the guides and valves. No need to change them if not necessary. You will have to grind all the seats if doing this as well.
16th May, 2009 at 11:28:40am
16th May, 2009 at 12:58:16pm
14mm. :) |
