Home > Help Needed / General Tech Chat > exhaust help please asap
jamz
Member #: 2292
Tool
Herne Bay, kent
i need to order a new exhaust for minispares to take down to brighton... atm ive got a maniflow downpipe and back box but need new back box... does a normal link pipe fit to the downpipe? or do i need a special one? or will the maniflow link pipe fit straight to a rc40 big bore back box
cant beat a good blowout.
what exhaust have you got already?
jamz
Member #: 2292
Tool
Herne Bay, kent
maniflow all the way through.... benross said that the engine he is building me will suffecate through that small exhaust
People often state that certain exhaust will not work, but when asked to back them up with some figures off back pressure or back to back test results we don't get answers.
jamz
Member #: 2292
Tool
Herne Bay, kent
so you think that my full maniflow "turbo" system.. wil be ok with some bigger power
Thats the thing, can't say either way unless someone test some propper testing. What's your exected boost & power output?
jamz
Member #: 2292
Tool
Herne Bay, kent
well benross is building me a full monte engine so i dunno really would be running about 15psi and hoping for about 170?
Buy a 2" Maniflow single box.
http://www.minispares.com/Product.aspx?ty=...INGLE%20BOX%202
Or a 2" play mini with 3" tail pipe.
Anton
Member #: 764
Staffordshire
The playmini one is quite a bit louder than the maniflow 2" system
Anton
Member #: 764
Staffordshire
littlejem59
Member #: 2544
Biddulph, Stoke on Trent
Do MS do a large bore (2"?) RC40? the only one i know is 1.75" OD which is proven good up to 125 HP then it starts to choke the engine. OK. for N/A but naff for a turbo IMHO.
It's not the age that makes me creak it's the mileage
jim if you phone up maniflow the single back box is only rated up to 120 bhp thats fact!
of course they will flow more but at the expence of
"tail pipe heat and flow" ..... resulting in power losses!
i have a spare in the workshop and i will compare my rocket launcher back box to the maniflow one next time, power figure wise. once i have sorted my fried clutch, its finding the time at the moment.
Thats fair enough if they have supplied figures, but are the figures going to be the same for forced induction?
IMO the most important part of any turbo exhaust system is the downpipe, as the gasses are at there hotest there so less dense. There for there will be more air flowing through the downpipe, than at the tail pipe.
but the restriction is at the back box jim,
the best exhaust is no exhaust with no restriction especially a charged engine
jamz
Member #: 2292
Tool
Herne Bay, kent
so back to my question... sod the rc40 then i will get a flethcer or playmini 2 inch system but what will i need to fit this to my maniflow downpipe?
stefaz
Member #: 1656
stoke-on-trent
an exhaust clamp??
jamz
Member #: 2292
Tool
Herne Bay, kent
cocky bastard haha... i ment size wise?
Jay#2
Member #: 648
Northern Ireland (ex AUS)
The playmini is 2" ID and 2 1/4" OD IIRC so you will need a downpipe with a swaged in that is 2 1/4" ID.
On 7th Nov, 2008 Nic said:
naeJ
m
jamz
Member #: 2292
Tool
Herne Bay, kent
well wahts the maniflow downpipe?
Jay#2
Member #: 648
Don't know but they might be a smaller bore than a playmini etc?
naeJ
m
stefaz
Member #: 1656
stoke-on-trent
my playmini fitted on quite well using a 54mm clamp i think it was. will check when i get chance, but no day off til next friday
jamz
Member #: 2292
Tool
Herne Bay, kent
so hopfully its just a case of buying the backbox and link pipe and should fit on :)
