| Home > Help Needed / General Tech Chat > Advantages of using an A+ block? | |||||||
2 Posts Member #: 6119 Junior Member |
15th May, 2009 at 08:12:39pm
hi after using the search function, i could not find the answer to my question and that being what would be the advantage of using an A+ engine over the normal one? thanks |
15th May, 2009 at 09:09:55pm
this is much lamented, but IMO the advantage is pretty much nil.
15th May, 2009 at 09:19:38pm
I thought they had a bit more metal in a few important places???
15th May, 2009 at 09:30:13pm
this is only my opinion, but i belive the older block was made of better metal, in engines i have torn down the bores usually seem less worn in pre A+ blocks. i'm sure people will disagree though
15th May, 2009 at 09:46:34pm
The physical difference is the "hole" over the centre main bearing on most of the "A" blocks - I have two spare ones and both have the hole.
16th May, 2009 at 02:09:55am
The A+ castings have extra webs cast into the outside of the block to stiffen it supposedly. Own the day
16th May, 2009 at 08:00:12am
I completely disagree with the material issu,
16th May, 2009 at 09:53:27am
There are A blocks without holes as well.
16th May, 2009 at 11:19:41am
thanks for the answers people. |
180 Posts Member #: 591 Advanced Member Rugeley, Midlands, England |
16th May, 2009 at 07:28:09pm
arrarently a blocks are stronger for longer stroke engines |
976 Posts Member #: 3228 Post Whore North of the Netherlands |
17th May, 2009 at 10:32:57am
So where would the MPi blocks fit in this story?
Dazed and Confused.... |
