Home > A-Series EFI / Injection > Interesting injectors?
jbelanger
Member #: 831
Montreal, Canada
Someone has pointed me to these injectors: http://www.xenocron.com/injector-dynamics-...ance-p-416.html. What is interesting is that they specifically mention a 1ms recovery time between pulses and a linearity within 1% with that interval between pulses.
That's the first time I have seen such a spec and it could resolve some issues seen by Paul S in his siamese code tests. I don't know the conditions and setup used to obtain these numbers. Also, the injector size could be useful in a staged setup.
Jean
http://www.jbperf.com/
Great stuff.
Exactly what we need for the second stage injectors for over 200hp.
Thanks Jean.
Also interesting about the 1mS recovery time. I'm convinced that this is very relevant with the sequential siamese mode.
Interesting as they are high z as well.
I can't actually see the Bosch part number anywhere in that advert to try and trace a detailed spec sheet.
That's the new Bosch EV14...getting good revies everywhere.
If you wanted a fast acting injector. Why not ram a few more volts into it ??
You can buy voltage boosters etc, that would pump say a fixed 16volts into them. Might make things work better ? and ensure stability ?
jbelanger
Member #: 831
Montreal, Canada
I don't really like the idea of a voltage booster. One more thing to go wrong. And more expense.
If you can have injectors with the specs shown in the link I gave, then it should be more than adequate. But these are modified since the EV14 are only available as 750cc/min.
Jean
Thanks Stevie.
This eBay add gives the Bosch part no.
http://cgi.ebay.com/ebaymotors/4-Bosch-028...eQ5fCarQ5fParts
Not a bad price either for four.
Anyone want a couple?
