Home > General Chat > Bending stainless pipe.
I have some 50mm OD stainless tube I need to bend. It's 1.6mm wall.
What's the best way to bend it, I have access to a hydraulic pipe bender will this work ok ?
I don't have much of the tubing, so don't want to waste it.
Phil.
PaulH
Member #: 2340
Dublin Ireland
What angle Phil if its anything more than 45 then you will need to use a Mandrial Bender but up to 45 fill the pipe with Sand cap both ends I normaly use good gaffer tape and bend very slowly.
On 17th Feb, 2009 Rob H said:
Or just buy proper stainless bends and weld them together.
Mr Joshua
Member #: 1954
Luton Bedfordshire
Dont bother unless you have a puka bender with wheels that follow the path of the bend, otherwise you will just end up crushing it. Tried the sand thing never worked well enougth. The only method I found to work well was by heating the surface thats being stretched.
Own the day
turbominivanman
Member #: 1504
Westbury, Wiltshire
I wouldn't bother Phil it's not worth the agro - particularly if the pipe's short - you'll wreck it.
Merlin do all the stainless bends you'll ever need.
I'm with stevieturbo on this - welding's the best idea.
Any stainless steel stockholder will be able to supply bends. They are used in the dairy industry, and pretty cheap really.
I always use this company for stainless bends.
http://www.milneroffroad.com/PIPE.HTM
There prices look good. Might be worth putting a ling in the 'Good Garages & Parts Suppliers' section
Try local stockholders.
I know a friend recently bought 6m of 2" stainless tube, 1.6mm wall and it was £33. The link above would be looking £60 for same
But do be aware most wont cut...so bring a hacksaw lol
Edited by stevieturbo on 22nd May, 2009.
That ones getting book marked
Mr Joshua
Member #: 1954
Luton Bedfordshire
Phil at those prices I would not even consider bending the pipe myself.
Own the day
I got chraper bends of ebay than milneroffroad, it may be worth just checking there first
I get mine from Dynoflow.
http://s229195592.e-shop.info/shop/categor...param=cid%3D%26
They are on eBay as well.
