Home > Help Needed / General Tech Chat > Worn Camshaft
RED850
Member #: 89
Sydney Australia
Hi Guys
tell me your thoughts please
I have a kent turbo cam baught new in about 98 only doen about 5ooo miles, i decided to pull my motor out last week to fix a small oil leak for registration and while i was there i decided to breakout the dial indicator and check my cam
here goes from cyl 1 to cyl 4
315thou exh, 200 in, 230 in, 290 exh, 294 exh, 219 in, 253 in, 314 exh.
such a big difference between them all
i read on another post that the avonbar phasr 2 is a real good cam, does any one have specs on it at all?
179hp on 12psi 1293cc of pure A series
14.0et @101 mph
The specs are out somewehre on this site... Keep searching - try ticking 'subject and text' in the search box...
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
sounds about right for most reground cams...
What you get is often very different to what it says it will be on the box!
If you measure about 5 or 6 you can normally find one good one!
alex
AlexF
Arno
Member #: 233
Beugen, Netherlands
does it matter?
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
for most poeple... probably not.
But if you want a great engine and you go to extreems you might as well not make an assumption on a critical part!!!
Alex
AlexF
