Home > Beginners Tech > Fitting a weber 45
stewart1
Member #: 6027
torpoint, cornwall
I want to fit a weber to a stage 3 engine that i just brought! Upon looking through the boxes of bits that came with the engine i found a spec sheet that the previous owner had typed up.
It states that the engine was built to breath through a weber 45:) on a 5.25" steel manifold!
Just trying to put a list together for other parts that i need to run a weber! So far iv got:-
weber 45
solid state fuel pump
filter king presure regulator
Also been told that i need to plumb in a return but not sure? *indifferent*
Any help would be greatly appreciated thank you*happy*
IF SPARKS DONT FLY IT'S TOO HIGH
lockfast
Member #: 2775
Aberdeen
You dont need a return and you will need a manifold for the weber. Whens the turbo or supercharger getting fitted then? *smiley*
You dont need a return, just the list that you already have
Paul
I guess you brought it home then..??
lockfast
Member #: 2775
Aberdeen
I wandered how long it would take!
Where did you wander to ? Lol.
lockfast
Member #: 2775
Aberdeen
I wandered back from the pub! Can you tell?
He wandered when he brought it home??
t3gav
Member #: 229
Gavin@minispares.com
kent
Misab plates, studs and nuts?
stewart1
Member #: 6027
torpoint, cornwall
Iv also got a metro turbo HIF44 and got my weber today! I'm going to see paul inch (think he races mighty mini's) tomorrow to see if there is any way that i can run a turbo through the weber!
Cheers for the help guys*happy*
If you'd done some searching you'd know that the 45SCOEs aren't suitable for this.
dcoe?
stewart1
Member #: 6027
torpoint, cornwall
Im only asking as i have the two units to choose from and i was interested to know whether it could have been done!*oh well*
lockfast
Member #: 2775
Aberdeen
You could have typed in the question to the search box just as quick? Then if you didnt understand something you could hvae asked? It saves a lot of the same questions comming up again and again and you would get alot more info and knowledge doing it that way.
youll also need to weld in a bulkhead box to fit the 5" fanimold
