Home > Technical Chat > transfer case advice
leroymornsey
Member #: 5265
telford
hi i am in need of a transfer case for my A+ turbo engine i have the block and gearbox but no case i no that the bearing is bigger on gearbox was wondering if anyone had ideas. i have a few other cases but non that seem to fit any ways to mod one too fit or will it be a case of finding turbo one thanks
garlic bread
Just use a regular bearing, it will be fine
leroymornsey
Member #: 5265
telford
so change to a standard bearing and is it just the bearing what about oil pump turbo one is just a bit bigger a it. or is it a case of just
modify the casting to make room
garlic bread
Monkeh
Member #: 1997
Lichfield
the turbo oil pump will fit, you wont have to modify the transfer case.
I did on mine...
Monkeh
Member #: 1997
Lichfield
i didnt.
Exactly, so stating that it isn't necessary is silly.
Powerflow high capacity (ie, the good turbo one with the steel cover plate) fitted mine without modification.
That was using a standard A+ transfer housing.
Best way is to try.....
I didnt even know there was an issue with the oil pump size
Im just running a regular n/a bearing and its all fine
leroymornsey
Member #: 5265
telford
thanks for advice chaps will try
garlic bread
