| Home > Help Needed / General Tech Chat > running my dampers upsidedown? | |||||||
7th Nov, 2004 at 06:14:06pm
hello |
8th Nov, 2004 at 08:02:40am
I had a similar problem, but solved it by moving my brace-bars up slightly on the inner wing.
8th Nov, 2004 at 09:18:55am
You would reverse bound and rebound damping...
AlexF |
8th Nov, 2004 at 09:21:56am
A common theory Alex.
8th Nov, 2004 at 09:32:25am
hmmm good point... direction of travel of the shox doesnt change.
AlexF |
538 Posts Member #: 119 Post Whore Staffordshire or Northamptonshire |
8th Nov, 2004 at 09:55:32am
reverse bound and rebound ???????
8th Nov, 2004 at 09:58:04am
bump, rebound, valving are unaffected. |
8th Nov, 2004 at 02:24:26pm
I did mean bump and rebound...
AlexF |
8th Nov, 2004 at 02:51:04pm
Gas and oil mixed going through the shock will totally change its characteristics.
8th Nov, 2004 at 05:23:48pm
No I take back my comment about bump and rebound swapping hence "hmmm good point... direction of travel of the shox doesnt change. "
AlexF |
9th Nov, 2004 at 09:39:59am
So which dampers can be run upside - a la Miglia to reduce unsprung weight? On 5th Sep, 2011 Vegard said:
9th Nov, 2004 at 10:08:27am
Do Miglia cars use remote resevoir dampers? these run "upsidedown" I think. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
9th Nov, 2004 at 01:21:56pm
Dampers are avaialble that can be run any way, up, down, flat. Its all down to the design of the volume compensation. I think most compotition gas shocks should be ok to run in different oriantation. Big advantage with remotes is you can make the body of the damper smaller, use smaller lighter spring and put the weight of the resovoir below the damper. The remote type have a pressurised resovoir. As the damper is compressed some fluid moves to the resovoir. They also have valving in. What are people running on miglia ? Think ive seen a few fitted with Ohlins, great quality stuff but damded expensive. You can get 3 and 4 way adjustable so you get high and low speed bump and high and low speed rebound !!!!!! So easy to loose your way with these things. |
9th Nov, 2004 at 02:29:33pm
What would you recomend as a damper for trackday use only....
AlexF |
9th Nov, 2004 at 03:20:48pm
I've heard great things about ohlins, but as mirage says, not cheap, also heard that quantumn and avo are good Team www.sheepspeed.com Racing
10th Nov, 2004 at 09:04:54am
I use Leda's on the front, Hand made to my spec for ?100 each. They do a fine job.
10th Nov, 2004 at 10:22:28am
I've used leda before and like the company... but never heard of anyone using them for mini stuff...
AlexF |
146 Posts Member #: 350 Turboing minis since '89<br> Supercharging minis since '04 |
11th Nov, 2004 at 09:43:15pm
i think it depends on whats in the shock, where the gas resevior is and whether the valving is in the body or on the piston, (which is usually where the adjustment is )i have seen ohlins because the factory is a couple of miles away and knew someone who built the shocks there , leda have been doing custom build mini shocks for at least 10 years with good results , i think its a case of if you want something specific it can be made at a cost , maybe cheaper to move the brace bars ! |
12th Nov, 2004 at 07:02:03pm
and less confusing?!?!
