| Home > Help Needed / General Tech Chat > Turbo engine smokey when on overrun? | |||||||
102 Posts Member #: 5814 Advanced Member Kidderminster |
28th May, 2009 at 04:55:24pm
Mini metro turbo'd mini.
More Boost, More FUN! |
28th May, 2009 at 05:01:37pm
My money is on the turbo oil seals. Also check your valve stem seals havent come off their seat. If something is worth doing, it's worth doing half of. |
28th May, 2009 at 05:16:48pm
Right, whats the implication of the turbo seals then? More Boost, More FUN! |
28th May, 2009 at 05:19:38pm
Turbo seals for sure. Implication? Well, it'll continue to smoke. It will likely get worse, but if it stops smoking then it's probably because your engine has stopped or its run out of oil.
28th May, 2009 at 05:44:50pm
Could be worn valve guides to. The oil will get sucked down under vacuum on overrun. |
28th May, 2009 at 05:45:44pm
as others have said, could be stem seals, rings but most probably turbo seals. if its the turbo seals then it will get worse, normally to the point that you pull up at traffic lights and the cloud of smoke seems to catch you up and waft past. |
28th May, 2009 at 06:02:18pm
If its only doing it on the over run I agree with phill, If the engine has not been rebuilt then you may find your guides are past there best, take the plenum off and look for oil in the top of the neck or on the joining hose. Edited by Mr Joshua on 28th May, 2009. Own the day
28th May, 2009 at 07:30:16pm
Thanks for everyones reply been helpful. Got an idea on the price of a turbo re-build anyone? More Boost, More FUN! |
28th May, 2009 at 09:21:25pm
or take the turbo off and try it n/a |
28th May, 2009 at 09:25:29pm
How'd you mean? To see if it still smokes? More Boost, More FUN! |
28th May, 2009 at 10:21:48pm
Yes, that would either confirm or eliminate the Turbo. |
28th May, 2009 at 10:33:27pm
your Turbo seals are GOOSED ! most likley
2646 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
28th May, 2009 at 11:29:42pm
Pistons was the only thing I didnt replace on mine, and guess what it was, lol, pistons!
29th May, 2009 at 07:37:40am
imo when its the pistons it tends to smoke a bit all the time and smoke more under load and especially when on boost. this can also be proven with a compression test.
29th May, 2009 at 07:45:40am
If it's only doing it on overrun, it's NOT the pistons/rings. On 13th Jul, 2012 Ben H said:
29th May, 2009 at 07:48:24am
if your breather aren't connected , you can first try this. It can help a lot oil seals.
29th May, 2009 at 02:27:04pm
Right, once again thanks for all the responses! The pistons are new and so are the rings the head was flowed and ported. Dont know whether guides were replaced but i know the stem seals were. Also had double valve springs in it. And last month i had the head off and the barrels are fine which eliminated me thinking it was the rings or pistons and the fact it only does it on the overrun.
29th May, 2009 at 06:33:42pm
To port the head properly the guides need to be removed. So unless they were stupid enough to fit the old guides again, they should have been replaced. |
29th May, 2009 at 06:48:07pm
Right well i shall speak to the bloke i bought it off about that...
30th May, 2009 at 05:08:51am
well any of the above how ever when my lands broke it was the same ran well, didnt smoke untill the over run when they were cracked, when the lands broke big style then she smoked like a barsted, how ever if the rings gaps are way to big like those crappy mega set i got this will also cause smoke on the over run as when on the over run oil gets dragedd past the rings, but start with the easy stuff first, then do a drop down test on the cylinders always looking for them bigger bunches of bannanas |
