Home > General Chat > Hypatec Pistons
eaton_mini
Member #: 1649
West Sussex - dreaming of forced induction!
Hi Guys, what sort of bore clearance are people using with these??
Going to get my block(s) bored out on monday so need to let the guy know this figure *oh well*
What size engine (ie, bore diameter) ???
eaton_mini
Member #: 1649
1 x 1380 (1275 +114) and 1 x 1040 (998 +120)
Standard is 2.6 to 3.6 thou piston to bore clearance.
I use 4 thou on the racer, but this means it does have a bit of blowby on the racer.
I can only speak for the 1380 (I actually used the 73mm pistions so am at 1360 but the 73mm and 73.5mm Hypatecs are the same design)
I used 0.06mm (2.4 thou) at the bottom of the skirt which is the top end of the factory spec.
Be careful with factory figures though, they are different top and bottom of the skirt (because the skirt isn't parallel on standard pistons). On the 73mm Hypatechs (at the least the ones I got) they had parallel skirts (in the load plane) most of the way up with reduced diameter ring lands and crown. Hence me quoting the bottom clearance which is the smaller one.
eaton_mini
Member #: 1649
So 2.4thou at the bottom of the skirt it is then :o)
I also use 0.06mm on my engines.
do you mean 2.36 thou?
whats with this metric crap...
eaton_mini
Member #: 1649
*happy* Metros were metric werent they??!?!
As long as we quote piston size in metric. ie 71.12 etc, it fucking ridiculous to quote clearance in imperial.
n.g.l.
Member #: 181
Chard, Somerset
In the Ebay listing below it give the clearances for the 73mm pistons about half way down the blurb. How useful this info is though is debateable as the seller is a numpty.
http://cgi.ebay.co.uk/Mini-73mm-Pistons-Ro...%3A1%7C294%3A50
Seems a good price though.
They went cheaply!
Edited by Vegard on 30th May, 2009.
tadge44
Member #: 2500
Buckinghamshire
Was that £50 ish each, or for a set ?
71.12?
do you mean +20 thou?
Oli
Member #: 1910
Wilts
eg. 2.8 inch lol
On 30th May, 2009 mini13 said:
71.12?
It must be the hot weather......
I can work in either units but metric is so much easier for doing calculations....
And the big Hypatecs are actually "genuine" metric sizes (73mm and 73.5mm).
Now back out in the sun everyone.....
sorry,I was only joking, but i think your right Rod, all this week i've been irritating the fuck out of everyone at work for the sake of it, must be the heat...
