Home > General Chat > Valve guides
tommy
Member #: 6230
Nottingham
Hi
Just wondering if anyone can help iv just had my stage 2 cylinder head converted to 36mm inlet and 31mm exhaust from 33mm and 29mm, iv also had bronze guides fitted but i think the engineer has reamed tham out to much thay have a bit of play side to side, should thay have play or should thay be a nice tight but loose fit if you know what i mean!!?
thanks
Rich
how much movement, , lift the valve 1" off the set and measure sideways freeplay,
You should be able to feel some movement, yes. But it shouldn't be excessive.
tommy
Member #: 6230
Nottingham
just had my dti on it and its 0.4mm to 0.6mm on inlets and exhausts
tommy
Member #: 6230
Nottingham
is that too much, i think it might suffer from smoking?
was that at 25mm off the seat,
Edited by fastcarl on 31st May, 2009.
fab
Member #: 100
Parisien Turbo Expert
Paris' suburb
I tend to prefer having a bit more play in exhaust guides, to let the valve expending.
0.4, 0.6 is ok, a bit tighter and you could kiss your cyl head and pistons.
A series tend to be smokey on overrun, try the last vuitton valves seals
tommy
Member #: 6230
Nottingham
when the cylinder head was on engine the engine would smoke when accelerating just a puff of smoke then clean up, and also if you had the engine ticking over for a long time, this is why i had the head done in the frist place, i just don't wont it to be the same
Put stem seals on the exhaust valves too...also what oil were you using ?
Stevie I've going to have to disagree with you on this one. The Ex valve gets very hot as we no, and putting a stem seal on them isn't a good idea imo as it needs some oil to lubricate it to help stop it seizing.
Yes better to have a little paly in the ex valves them be tight i've found.
tadge44
Member #: 2500
Buckinghamshire
And, as previously discussed on this forum, oil is highly unlikely to be sucked down the exhaust valve guides - there is suction is on the inlets on a closed throttle but I cant see how the exhaust has anything but positive presure except for VERY brief intervals due to pressure waves bouncing up and down the exhaust.
fab
Member #: 100
Paris' suburb
Your turbine suck thru exhaust guides when your closing your throttle,
secound Matt, doesn't use exhaust seals, to keep a bit of oil going to the guide, prfer to have a light smoke on overrun than to keep my guides dry and tight on stem.
I agree, I never fit them on the exhaust on any of my heads.
tommy
Member #: 6230
Nottingham
thanks people il keep that in mind, but the oil im using is 15-40 is that ok?
tadge44
Member #: 2500
Buckinghamshire
Thank you fab - I was thinking N/A not turbo so was quite wrong about exhaust suction.
fab
Member #: 100
Paris' suburb
10/15w50 motorbike oil, or 20w50 millers cv, what else?
I know what you're saying...but every modern turbo car Ive worked at, has seals on both.
Ive no notion if I used seals on my old turbo though...too damn long ago. But I konow when I first started wtih the turbo engine, oil n overrun and at idle due to valve guides, was a nightmare problem.
Ive a feeling I deepened the oil drain grooves, and fitted stem seals.
I didn't know that about moden engines Stevie. Emm, some thing to thing about then maybe??
i run sprung plastic seals on both ex and inlet ,and also run tight clearances .
