| Home > Help Needed / General Tech Chat > SuperCharger Parts suppliers | |||||||
10 Posts Member #: 5930 Member |
2nd Jun, 2009 at 11:59:16am
Was wondering if anyone had a link to a good supplier of parts for SC?
Edited by Winston on 2nd Jun, 2009. |
2nd Jun, 2009 at 12:10:59pm
I assume you refering to Super charger parts? Are you looking for Kits or parts for the actual supercharger? Team www.sheepspeed.com Racing
2nd Jun, 2009 at 12:15:52pm
I'm really looking for parts. I have the charger, I've made my own inlet manifold.
559 Posts Member #: 2775 Post Whore Aberdeen |
2nd Jun, 2009 at 12:42:31pm
Not sure I am with you! What are you looking for? Pullies etc? I would have thought you needed this before you made a manifold as that is what gives you your spacing etc. So just to be clear you have an M45 and an inlet manifold - nothing else? So you are looking for a bottom pulley a tensioner some form of fuel inlet either for carb or injection? I am guessing you are bilding a suck through setup? Give as much info as you can and you will get more info back. |
2nd Jun, 2009 at 02:07:43pm
On 2nd Jun, 2009 lockfast said:
Not sure I am with you! What are you looking for? Pullies etc? I would have thought you needed this before you made a manifold as that is what gives you your spacing etc. So just to be clear you have an M45 and an inlet manifold - nothing else? So you are looking for a bottom pulley a tensioner some form of fuel inlet either for carb or injection? I am guessing you are bilding a suck through setup? Give as much info as you can and you will get more info back. Oh dear - looks like I may have made a boo-boo then. Here's what I have: Eaton M45 Inlet Manifold Induction pipe - including machined in threads for injectors Yes, I'm going for a suck through set-up, but did consider a blow through - but i believe charge robbing is a problem. |
2nd Jun, 2009 at 02:16:54pm
If the supercharger needs a rebuild, I'm sure that it will be cheaper to get a new blower off ebay than try to repair.
Edited by Paul S on 2nd Jun, 2009. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
![]() 667 Posts Member #: 5232 Post Whore basingstoke |
2nd Jun, 2009 at 03:03:45pm
If you're building your own setup, why not go blow through? Suck through seems like such a bad idea!
Mr. Prawn, the friendly Crustacean- slowly making steps towards forced induction. |
7th Jun, 2009 at 04:10:11pm
On 2nd Jun, 2009 Paul S said:
If the supercharger needs a rebuild, I'm sure that it will be cheaper to get a new blower off ebay than try to repair. You will not get away from the charge robbing issue just by using suck through with injection. The fuel slugs will get dispersed but they will still be slugs that go anywhere they want. There are some photos somewhere on here of a supercharged and injected engine that had clearly suffered charge robbing. Here: http://www.turbominis.co.uk/forums/index.p...id=242798&fr=25 Regarding the charge robbing - I've mounted the injectors quite away up the inlet tract, surely the fuel will follow the airflow into the cylinder that is on the induction stroke? Or have i got it totally wrong (which won't be the first time - according to wife) |
7th Jun, 2009 at 04:22:02pm
Injcetors do not work like carburetors that feed a continuous stream of fuel into the air.
