| Home > Help Needed / General Tech Chat > Excessive brake pedal travel | |||||||
![]() 1547 Posts Member #: 2727 Post Whore Bicester |
5th Jun, 2009 at 08:53:16am
Morning guys, driving to work this morning i found that the travel on the brake pedal was more then usual, brakes still worked. when i gave it a pump, it returned to normal and then it would fade again. i had a look cant see any fluid leaking and the master cylinder level is fine. could it be the back brakes need adjusting.replacing? im running minisport 4pots and std rear drums, with a std master cylinder. any ideas?
1972 998 TURBO SLEEPER |
5th Jun, 2009 at 09:22:29am
Most likely the rear drums need adjusting, as a test, pull on the handbrake a couple of clicks and see if the pedal travel drops, if it does then adjusting the brakes up will sort it.
147 Posts Member #: 814 Advanced Member Utrecht, The Netherlands |
5th Jun, 2009 at 09:23:46am
It sounds like air got into your brake system, so I would try bleeding the brakes first. Rear brakes do need adjustment now and then, but this can't cause a sudden increase of brake pedal travel. |
5th Jun, 2009 at 11:15:22am
Thanks guys ill give it a try tonight 1972 998 TURBO SLEEPER |
5th Jun, 2009 at 11:46:46am
As a rule brake fluid should be replaced every year or is it two years? How old is the fluid in your system? But go with the adjustment first. Own the day
