Home > Help Needed / General Tech Chat > 10x10s?
Mr Mini
Member #: 346
Portsmouth
Does anyone know whether it is possible to fit 10x10 wheels if ultra low profile tyres are used with a steering rack limiter http://www.kad-uk.com/accessories.htm
Trying to guage what widest wheel can be fitted without any serious modifications. I have no problem using the steering rack limiter as the steering lock on a mini is pretty damn good to start with anyway.
Also I believe the 10x8s is the limit for rear wheels without doing arch modifications, but is this for low profiles does anybody know?
Thanks.
1310cc TWINK - T Conversion
Kean
Member #: 341
aka T2clubby
South Staffs
I doubt that the profile of the tire is the limiting factor here, more the fact of a 10" rim. In order to clear the inner arch etc, you would need at least a zero offset, which would leave you with no wing left after cutting it all out I imagine.
Personally I wouldn't fancy trying to drive a mini with 10" wide wheels at the front, my old car ran 17*10 all round, and would tramline terribly befire I reduced the fron tire size.
Also I cant see you getting road tyres for a 10" rim, unless you go for some extreme stretch on a Yoko!
I don't know of any road legal tyre that fit a wheel of that width! TBH I think it would ruin the handling.
Mr Mini
Member #: 346
Portsmouth
Iv found these rims:
http://www.danacreechracing.com/categories...roduct-329.html
But not any tyres. What do you think would be the limit? 10x8?
I think 6" is the limit for road tyres, 7's if for slicks only IMO
I'm sure that link has been on here before, at $1000 plus shipping for a set of 4, plus the questions over whether they'd take the forces of a slick shod Mini on tarmac, I'm not sure I'd bother.
Kean
Member #: 341
aka T2clubby
South Staffs
I doubt those rims would be deemed road worthy?
10*8 I think is the maximum you caould stretch a normal tyre on to. Dont get too hung up on having the widest possble, it can really ruin the feel of a car.
Mr Mini
Member #: 346
Portsmouth
OK il sway away from these...all negative it seems!
Cheers.
forget the width, look at the rim design, you wouldn't get any propriatorty disk set up under inside the rim,unless it fit inside a 7" dia,
I bet tyres are a bitch to put on those rims!
BadgerBaiter
Member #: 2257
Brighton
I have 9 x 10 rims.
I can get Dunlop Special wheels for these - they are 8 x 10s but they can be used up to 9inch width. . ..
http://www.jolyonway.com
I think I've got at least 20X10" rims...
Kean
Member #: 341
aka T2clubby
South Staffs
Don't be so greedy.
BadgerBaiter
Member #: 2257
Brighton
LOL.
I don't think I'll be keeping them, as I want 7 x 10s
my thought is why... no tyre company makes over a 165 for 10's which are road legal and rated over 60mph, imo it would look silly fair enough if its just for drag but on the road =/
i think a few people are running wider with 032's and no problems
