Home > General Chat > 9 lives
longy
Member #: 2727
Bicester
Hey guys i think ive used up all my nines. in the last month ive had the head gasket go and it didnt warp the head. then week before last the flywheel retaining bolt spin loose and jammed the clutch, thank god the flywheel didnt spin on the crank, torqued up the bolt and all was good. then today driving home front left was making a funny noise. pulled over and the hub nut had come off. shat myself !!!! big time. got the miss to run me home where i had a spare nut waked it back on and limped home. just had a look and all seems well, looks like the disc brushed the in side on the caliper but check all the clearence and all is ok.
im really starting to think driving this car everyday is too much. what do you reckon give up the mini as the everyday car? only issue is that would mean id need a new car and that means no turbo project !!!! *surprised*
1972 998 TURBO SLEEPER
Sam
Member #: 1686
Oxford
Good you stopped when you did bud. You shit a brick though when you sore it?
OMG Robert that's a big one
longy
Member #: 2727
Bicester
hell yeah, nearly kicked the door in lol, was so pissed off with it.
Shit that was lucky! Don't let it put you off, I had mine as daily driver for quite a while. It does get annoying sometimes when you're constantly having to fix it each evening, but eventually you'll get to a point where there's nothing left to fix! Lol
longy
Member #: 2727
Bicester
lol good point matty. now im moving closer to work it should be ok. i cant give it up ill have to have conversations with the miss and she would want me to sell it lol not gonna happen !!!
richminiturbo.
Member #: 719
Horndean - Near Portsmouth
Just teething problems.
Albeit really fcking dangerous ones hahha.
I'm not having a go or trying to be a BAC, but where was the split pin in your CV joint nut???
EDIT: I think I am dislexsic (or how ever you spell it)
Edited by apbellamy on 5th Jun, 2009.
I guess shitting a brick would make it quite sore...
Sam
Member #: 1686
Oxford
Fine saw then; ignore my lack of ability to spell.
piquer!
longy
Member #: 2727
Bicester
last time i looked the split pin was in there.
