| Home > A-Series EFI / Injection > Siemens Injectors | |||||||
8th Jun, 2009 at 04:30:11pm
Finally got my 60lb injectors from Aus.
Edited by Paul S on 8th Jun, 2009. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
8th Jun, 2009 at 04:50:01pm
With that slender body 16mm apart and parallel to each other looks feasible.
8th Jun, 2009 at 05:08:54pm
It should be fine side by side even if it may slightly favour one cylinder over the other when staging is off. As long as you have the outer injectors as primary and the inner as secondary (or vice versa) to have things symmetrical on both intakes and not pair them left for primary and right for secondary.
8th Jun, 2009 at 05:27:51pm
What cc's are these equivalent to Paul?
8th Jun, 2009 at 05:30:34pm
630cc/min according to the blurb.
8th Jun, 2009 at 06:15:40pm
Sounds like they are the same as we have, apparently from what I've gathered a very good injector.
8th Jun, 2009 at 07:46:44pm
i was going to suggest making injector bosses with two holes, but it sounds like youv'e thought of that.
On 8th Jun, 2009 Paul S said:
630cc/min according to the blurb. Not really big enough for 200+hp on a 1293 Turbo but a good starting point. 5 port that is. I'm thinking now about getting a couple of blocks of ali to make a combined flange and injector boss. This will minimise the welding and potential distortion. On 28th Aug, 2011 Kean said:
8th Jun, 2009 at 07:52:26pm
I'm now trying to find out if the EV14s are the same length, but struggling.
8th Jun, 2009 at 08:49:48pm
Back into proper units..... how many cc/min are you looking at in total for (say) 200bhp and at what duty cycle ???
8th Jun, 2009 at 10:15:46pm
On the basis that I got equal AFRs on my 998 up to 6000rpm and, say, 60hp with 375cc/min injectors on a single pulse, then by my calcs, 240hp would be possible with 1500cc/min per port.
9th Jun, 2009 at 01:01:19am
Siemens Injector..........
9th Jun, 2009 at 10:10:45am
On the basis that I got equal AFRs on my 998 up to 6000rpm and, say, 60hp with 375cc/min injectors on a single pulse, then by my calcs, 240hp would be possible with 1500cc/min per port. Allowing for 7000rpm, then a lttle bit more from two 840cc/min injectors per port should do the job. Single pulse. I'm not convinced you can work it out from a theoretical duty cycle in this instance, but you could work back from the above numbers. I did a quick mental calc and I thought it was around 15%, but don't quote me. The actual duty cycle calculates out at 41.25%, using 240hp and 0.55 BSFC. So that is just over 20% of the cycle that it is going into a single cylinder. I think. Working back, my 998 using the 375cc/min and 60hp gives 46%. Edited by Paul S on 9th Jun, 2009. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
9th Jun, 2009 at 10:54:06am
Working your figures the other way around (I've used tables off the internet to see what size injector(s) I require) and using 0.47 BSFC (more commonly quoted for intercooled engines) I get pretty much the same....
9th Jun, 2009 at 12:18:35pm
On 9th Jun, 2009 Rod S said:
The reason I've been working the other way around is that (at the moment) I'm determined to keep duty cycle low enough to still run individual pulses so wanted to know what injector size I needed to achieve that and I'm working on the basis that 20% will keep the pulses far enough apart even with moving the timing around to balance AFRs. The fact that I managed to get another 2000rpm out of the same smallish injectors by going from two pulses to a single pulse, with everything else being the same, tells me that you lose a lot in duty cycle terms if you want to stick with the two pulse mode. Edited by Paul S on 9th Jun, 2009. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
9th Jun, 2009 at 01:03:15pm
Yes, that's why I said "at the moment"......
9th Jun, 2009 at 01:04:29pm
So my problems may have been due to the loss of pulse, rather than injector size? Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
9th Jun, 2009 at 01:24:34pm
Possibly - without a scope you can calculate the maximum pulse width before merge becomes close with basic 90/90 timing, but once you start moving the injector timings, and especially if you are moving them in tables with different differences at different RPMs, it all becomes a lot harder to try to visualise.
