| Home > Help Needed / General Tech Chat > timing gear tensioner | |||||||
492 Posts Member #: 3684 Senior Member wisborough green west sussex |
9th Jun, 2009 at 09:50:23pm
i have just put on a swiftune duplex kit and i was wondering if i need to put the old standard tensioner back on or not bother? |
147 Posts Member #: 814 Advanced Member Utrecht, The Netherlands |
9th Jun, 2009 at 09:56:18pm
Don't bother, you don't need the tensioner on the duplex chain setup. |
9th Jun, 2009 at 09:59:15pm
Personally I do fit the tensioner. Duplux or not the chain can still have slack in it without.
9th Jun, 2009 at 10:07:25pm
I've also used the tensioner on a duplex chain, they are just about wide enough to do it....
9th Jun, 2009 at 10:08:34pm
i always use a tensioner, and quite frankly wouldn't dream of leaving it off, |
9th Jun, 2009 at 10:12:43pm
right thats that then stick with! thanks guys. |
10th Jun, 2009 at 12:31:07am
Chains dont stretch, they wear On 26th Oct, 2004 TurboDave16v said:
10th Jun, 2009 at 07:58:24am
On 10th Jun, 2009 Sprocket said:
Chains dont stretch, they wear picky
As they wear they get longer - as if they had stretched :) Schrödinger's cat - so which one am I ??? |
10th Jun, 2009 at 11:01:20am
also while we are on timing gear does the splash plate matter that goes over the cam? |
10th Jun, 2009 at 11:13:05am
Do you mean the one spot welded to the inside of the timing chain cover ???
10th Jun, 2009 at 12:41:08pm
no not on the cover it self, its like a big washer that goes onto the crank or cam i cant remember. |
10th Jun, 2009 at 12:50:13pm
it's going on the crankshaft
10th Jun, 2009 at 01:09:51pm
yer do i need this also? or can it be lost? |
10th Jun, 2009 at 01:14:07pm
The big "washer" is an oil thrower, it's dished and only goes one way around.
10th Jun, 2009 at 01:27:59pm
thats the one ok great thanks rod! |
10th Jun, 2009 at 04:38:30pm
I suspect running without a tensioner will cause exrta grag on the engine as the chain will have a little whip in it added to that the sympathetic vibrations that might be caused could increase ware rate, just a thought Own the day
