Home > Help Needed / General Tech Chat > Fitting A panels
As I don't have a spot welder (only got got a MIG) any suggestions on how best to join my A panels to my wings? and no Smart Alec comments please.
Borrow a spot welder would be my advice, super neat job, and a fraction of the time it will take you any other method.
evolotion
Member #: 83
Glasgow, Scotland
drill holes in one panel and plug weld them :) if you cant borrow a spot welder *tongue*
Edited by evolotion on 13th Jun, 2009.
Denis O'Brien.
I plug welded mine, but have decided to take one of to re do a bit of bodgery underneath so will be using my shiney new spot welder next time round *smiley*
Was a PITA cleaning the welds up though...
As your only fitting half wings, it should be easy to just put some nice slugs on the inside.
Rick
Aaaarrrrggghhh - I've just taken two A panels off and one was fitted this way by someone who hadn't used a spot welder....
What a mess - it took over an hour with an angle grinder and die grinder to avoid wrecking the A pillar itself.
The other side (original factory three spot welds) took about 5 minutes.
Mini_Andy
Member #: 432
weld it from behind :)
Mr Joshua
Member #: 1954
Luton Bedfordshire
Three holes job done.
Own the day
If youre fitting a flip front i suggest fiiting a brace bar from the inner wing to a panel. I did it this time around and its excellent! A gorrila could swing off em!
That's a bit worrying. I never welded my A panel ends on my A panels. Will that be an issue??
I folded the edges over nice and tight using a door skining tool.
turbominivanman
Member #: 1504
Westbury, Wiltshire
Rob.
Plug welded mine on the van with about 8 plugs per side but was a bit of pain doing all the grinding back afterwards as it's a bit fiddly. Luckily, didn't have to do too much as the seam cover goes on top.
If I had to do it again, I'd borrow a spot welder.
Also recommend you replicate the factory mig / gas welded little L shape piece, one each side, that goes at the bottom of each A Panel / wing joint. This'll stop the joint flexing and cracking.
Must admit - I dont like the idea of welding from behind but each to their own.
Richard.
