Home > For Sale > 1293cc NEW Build short Engine HI SPEC
right gents *smiley* here we have a freshly built high spec 1293 cc short engine for sale due to a let down.
The following spec is ...it sports the superior 6581 crank
CNC bored and honed to + 0.020" within intolerance of 5 microns. all oil gallery plugs pulled and hexagon plugs fitted and new core plugs fitted
OMEGA cast pistons 10ccs , ARP rod bolts, centre main strap, new oil pump, new followers, main bearings, big ends and thrusts.
Phase 2 cam timed in at 108 degrees precisely, steel duplex and chain, complete with cover and seal and crank damper bolt ..etc
including with this is a ultra light steel flywheel pre engaged, backplate with lugs machined 1.5mm for more clamping load, triple drive straps, all new bolts, AP RACE PLATE, double grey cover,the whole assembly has been precisely balanced to 10,000 rpm ...............not as though you should get there.
This engine with the right cylinder head, turbo, gearbox, drop gears........etc is capable of producing 200 bhp plus++
This engine in some go faster speed shops is in excess of .......... "£2000 +VAT check it out !
My price is £1750 exchange buyer collects or I can meet within 100 mile radius of Pontefract, West Yorkshire.
Maybe you want one of my heads to compliment this engine which can be arranged. Please PM me if you are interested *smiley*
Edited by BENROSS on 18th Jun, 2009.
Looks sweet Steve. This is what people should be buying instead of the junk that sells on ebay.
many thanks phil, i will guarantee this motor
philc
Member #: 1346
bromsgrove
i like the idea of cnc the bores rather than the conventional way. mmmm.
I do think that CNCing by now IS the conventional way...
jamz
Member #: 2292
Tool
Herne Bay, kent
*wink* nice engine.
cant beat a good blowout.
philc
Member #: 1346
bromsgrove
not where i would go
This has just popped on your club forum.. should have said it was a BenRoss motor will add some value.
Will do! *wink*
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
mate id have that is a flash but im way to far away lol i well
You are also 3 years too late! lol
*surprised* lol
maccamcvey
Member #: 6673
Worral Sheffield
this engine is still sat in my garage awaiting the bodywork to be finished!
