| Home > Help Needed / General Tech Chat > Cleaning Valves | |||||||
![]() 63 Posts Member #: 264 Advanced Member Southampton |
15th Nov, 2004 at 12:54:29am
Im currently rebuilding an 1987, 65k turbo engine Yes, Im getting there.....
15th Nov, 2004 at 03:07:13am
i just use a wire brush in the end of me drill On 20th Oct, 2015 Tom Fenton said:
15th Nov, 2004 at 09:21:45am
Get them bead-blasted while you have them regrinded. On 13th Jul, 2012 Ben H said:
![]() 362 Posts Member #: 114 Senior Member Porto/Portugal |
15th Nov, 2004 at 07:34:20pm
I use "White Spirit" Pedro Silva
16th Nov, 2004 at 05:50:11pm
what i use and have done so for many years is put the valves in a elec hand drill spin them up, then use somp P40 grit paper to take the worst off, then use p 80 grit, then say p180 working my way down the papers i find this enough, but if you wish you can use say 320 wet dry to give a nice polish to finish with.
17th Nov, 2004 at 12:22:50am
Thanks alot guys, I had thought of using a hand drill but wasnt sure if it was a big no no.
17th Nov, 2004 at 09:14:42am
its a good idea to wrap the valve stem in electrical tape or somthing so that the drill chuck cant damage the stem.
AlexF |
17th Nov, 2004 at 10:13:54am
Remember to have the valves recut EVERY time they are out of the head. It's silly not to, as they wear sufficient not to seal after 10000miles. On 13th Jul, 2012 Ben H said:
18th Nov, 2004 at 10:48:47am
Vegard: i have never come across the actual valves been cut ?
