| Home > General Chat > Rear castor is out....who makes best brackets? | |||||||
869 Posts Member #: 2443 Post Whore Cheshire |
21st Jun, 2009 at 10:57:55pm
Alright Gents,
21st Jun, 2009 at 10:58:59pm
There is no castor angle on the rear. I guess you mean camber. 1,5 degrees is a bit much on the street I guess.. On 13th Jul, 2012 Ben H said:
21st Jun, 2009 at 11:00:46pm
KAD Brackets are supposed to be the best at the moment |
250 Posts Member #: 1615 Senior Member Ferndown, Dorset |
21st Jun, 2009 at 11:14:09pm
im going to get kad ones, ive got huddersfield ones on at the moment and there shite. there camber only not toe and there set at max and ive got 0 deg camber, and slight out, and at first i thought there were fitted wrongly but there not. On 1st Mar, 2009 MikeRace said:
Hmmm weberyyy On 21st Apr, 2009 madcatminis said:
I hope she's got knickers on or you'll have a funny runny mark on your bonnet. Quite like what a snail leaves behind. |
21st Jun, 2009 at 11:19:31pm
Hi Vegard, they only add 1.5 degree of negative to what was already there, it used to run positive camber as standard so they wont be making the full 1.5 of negative.
Edited by Andy500 on 21st Jun, 2009. |
21st Jun, 2009 at 11:23:39pm
Just seen the KAD ones and they look pretty good but are £65 more expensive than the Minispares ones, are they worth it? I like the sound of indestructible though! |
21st Jun, 2009 at 11:29:05pm
he mini sport ones are a similar design to the Kad ones, not as nicly made though. On 28th Aug, 2011 Kean said:
21st Jun, 2009 at 11:39:36pm
KAD ones are most substancial but more tricky to correctly adjust than the Minispares one which need a bit hacksawing off for some reason! On 5th Sep, 2011 Vegard said:
22nd Jun, 2009 at 08:22:49am
Very carfully inspect and measure everything. You won'y have just 'knocked' the front toe out, you'll have bent something. You need to find what you'vr bent. Adjusting the toe at the front will just mask the problem.
22nd Jun, 2009 at 08:28:22am
From my source at Minispares, the KAD ones are well worth it. On 13th Jul, 2012 Ben H said:
22nd Jun, 2009 at 09:30:34am
Right, the KAD brackets it will be then. Cheers gents.
22nd Jun, 2009 at 09:34:39am
Just to make doubley sure im gonna have another look at the front setup tonight. What do we think is most likely to bend? Tie rods?, steereng rack? |
![]() 84 Posts Member #: 5645 Advanced Member middlesex ( near heathrow ) |
22nd Jun, 2009 at 09:48:53am
both? Don't go slow !!! Go Turbo :)))))) |
22nd Jun, 2009 at 10:39:46am
I've bent steering arms and tibars in less of an inpact than it sound's like you had. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
