| Home > A-Series EFI / Injection > help, taking the efi way | |||||||
24th Jun, 2009 at 12:11:54pm
Well that's a while this is in my head,
24th Jun, 2009 at 12:28:00pm
Fab,
24th Jun, 2009 at 12:31:18pm
hI Paul, I've just ditched the turbo to set up efi.
24th Jun, 2009 at 12:36:26pm
In that case you will need the MS built to incorporate either Jean's P&H board for low Z injectors, or the Quad driver board for high Z injectors.
24th Jun, 2009 at 12:50:48pm
Welcolme on board Fabrice,
24th Jun, 2009 at 01:10:33pm
manifold wil be a simple tube taking motorbike itb, that's why I woul like to build the raised port head, then if I I've trouble with the efi , it will only be a sawp for the set of cvk40 |
559 Posts Member #: 2775 Post Whore Aberdeen |
24th Jun, 2009 at 01:24:34pm
Would I need to run the same setup as you turbo guys if I was looking to run a suck through supercharger using two MPI injectors mounted in the opening to the charger similar to the vmax setup? |
24th Jun, 2009 at 01:29:31pm
no, suckthrough is easier EFI wise. That would be like an electronic carburettor so to speak |
24th Jun, 2009 at 01:31:10pm
No, not if you mean the Megasquirt with siamese code.
24th Jun, 2009 at 03:08:18pm
Fabrice,
24th Jun, 2009 at 03:16:33pm
That reminds me that as well as get the Turbo on the 998 within the next three weeks, I also need to listen to my Teach Yourself French CDs before I head off to the Med Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
24th Jun, 2009 at 03:39:13pm
I like the bit about the Quebec accent..... in written french ?????
24th Jun, 2009 at 03:52:10pm
That's why I put the smiley. But we do have quite different expressions and even use different words for certain things. And the funny thing is that we both use English words (anglicismes) but often not the same.
24th Jun, 2009 at 08:09:53pm
oh Jean!
24th Jun, 2009 at 08:11:26pm
Franglais will do !! Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
24th Jun, 2009 at 08:51:39pm
On 24th Jun, 2009 Paul S said:
Franglais will do !! Agreed - I can read/speak some french but, to fully understand Jean's post, I did have to resort to my Babel Fish..... Schrödinger's cat - so which one am I ??? |
